Have an overclocking problem
Cooling unit starts, runs for a second then stops.
  • 456 Answers
I think it is the voltage problem because that ups leave the power supply, for more explain your problem briefly.
Posted on Dec 12, 2007
Panasonic heat pump
Sounds like that's the relay clicking to run the blower motor .Check on your unit outside and see if the compressor is short cycling ,meaning it would run ,stop ,run ,stop .
If that's the case you have a bad install .
Maybe unit is shutting off on low pressure meaning no refrigerant. If that's the case you have a leak in the system that need to be fixed
Jun 01, 2017 | Heating & Cooling
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
Hp D8x43UA ABA
You have a laptop computer; it is more than likely that the BIOS will not allow overclocking for that unit. Most laptops cannot be overclocked for good reason; they have limited resources and poor cooling engineering. O/clocking produces high heat and they just don't have the setup for additional cooling. For the most part that also applies to most retail desktops as well. The majority of overclockers use custom-built units with CPUs adn motherboard BIOS' that are set up for overclocking, such as Asus and Asrock boards. I overclocked my home build unit, but installed a water cooled system and extra case fan. Standard retail etail units are just not set up with that kind of quality.
Mar 11, 2014 | HP Pavilion a350n PC Desktop
Evga P55 Classified Motherboard Unlocked K Intel Processor Overclock Walk Through. 4.2GH Goal.
Suggest sir you go to an overclockers website.
May I suggest a couple?
1) http://www.overclockers.com/forums/
2) http://forums.extremeoverclocking.com/
I would say liquid cooling, Nitrogen cooling, or refrigerant is in your future.
(But that's just me. You probably won't stop at your stated goal, lol!)
Regards,
joecoolvette
Nov 26, 2012 | Computers & Internet
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Overclocking failure!!!
Pull your cooler off the processor and clean off the thermal paste and reapply. Seriously think about putting some bucks into a better way of cooling that monster if you are going to be overclocking. 185 degrees is pretty warm, you probably just baked the thermal paste, replacing it will get the cooling effects back in place.
Dec 20, 2009 | ECS 945P-A (V3.0) Motherboard
Air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Jan 24, 2009 | Fujitsu 24C1 Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Open Questions:
How to Save Data Backups for 100 Years - Data Backup and Online STORAGE Get all you important data saved safely and securely on the highly advanced online cloud backup solution of Dataalign. This facility of providing large space for online cloud backup is different from its counterparts as it makes optimal use of advanced technology to device features that helps the user to make maximum use of the available space by setting the number of versions and days you wish to keep a file after which it is automatically deleted. Also, the feature of version history helps in viewing the history of each stored file and thus, also let's undo decision mistakes if made in the past. The server cloud backup solution of Dataalign is an amazing way of backing up all your files, folders and data whether related to your business or personal. Many more amazing features of Dataalign makes it super secure and easy to use by anyone. There are different categories of backup plans in Dataalign for various uses. You can choose the plan according to your needs from home free backup, personal standard backup, social backup, personal pro backup, family all in backup and home pro all in backup. The Unified cloud backup feature of Dataalign cloud backup helps in securing data located on various platforms and in different devices at a single place. Everything on your computers, tablets, and smartphones, external drives, servers, network devices and even cloud services like dropbox automatically get imported and saved on Dataalign. The cheap online data backup of Dataalign provides easy access and retrieval of data from any place using any device. Free cloud data backup of Dataalign helps in protecting all your data like documents, photos, music, videos, contacts, messages, calendar, call logs etc. In case of situations when your device gets damaged or you want to upgrade your device, you won't have to worry about transfer of data. You can import all your data by simply installing the Dataalign cloud backup app. With Dataalign keeping all your data safe, you can search and discover documents, presentations and spreadsheets from any device. You can even discover OCR content from scanned PDFs and images. For more information and cheap online cloud backup contact Dataalign at toll-free helpline number +844387-9959.
Sep 21, 2018 | Super Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
