Question about Krups XP 4050 Espresso Machine
No water through the head!!
Makes all the noises of making a coffee but no water comes through.....steam is okay and hot water is okay but no water for brewing the coffee....any ideas???
I have tried to descale it but no good so far!
  • 3 more comments
  • Anonymous Jan 09, 2008
    Machine recently descaled and parts cleaned. Did not solve problem.
    A bit of water squirts out sides of head, thought not screwed on tight enough.
    Could the rubber ring sealer thing need replacing ? Machine approx 2 years
    old.
  • rpg55 Feb 18, 2008
    have the same problem, water just goes into the overflow tray and doesnt go through coffee-had it into the shop twice, both times they replaced the flow valve and still does same thing. anyone know how to fix??
  • Anonymous Mar 08, 2008
    I had the same problem, no water out of the head and all water was going to the drip tray. I descaled it and everything was fine. This "clog" happened only after 3 weeks from purchase ... will have to check my bottled water quality!
    I bought some citric acid at the supermarket and mixed up 2L of warm water with 3 tablespoons of citric acid. Then I ran the hot water function for approx 1/2 liter then ran it through the head for another 1/2L although it continued to leak out to the drip tray.
    I reapeaded the above (1/2L through the hot water and the last 1/2L througth head). This time the water came through the head as it is supposed to.
    I flushed it clean with 4L of fresh water through the head and hot water, now I am back in business.
    Hope this helps others facing the same problem.
  • Vince D'Angelo Sep 08, 2008
    Thanks!
  • Willstar Apr 14, 2009
    Exactly the same problem... no water through the 'head' but everything else ok. this is a brand new machine though so will be going back to the shop!!
I had the same problem - all water going down into the tray at the bottom - virtually none through the coffer basket. I couldn't find citric acid at the store to descale so I used white vinegar instead. I 3/4 filled the reservoir with warm water, and added about 1/2-2/3 cup of vinegar. I first ran water through the 'hot water' button (it comes out the steam spout). Then I ran the entire reservoir through the machine using the 2-cups option. It started running right away. I rinsed out the reservoir with fresh water, then ran a whole reservoir of fresh water through the machine to get rid of the vinegar smell. The first cup of espresso after this treatment was as good as ever. Phew! I thought we were up for a new machine!
Posted on May 26, 2009
Unbelieveable, I tried the vinegar and water flush and did exactly what nquigley did and wow. first time ran right through the head! thanks nquigley, enjoying great latte's again.
Posted on Jan 10, 2010
Posted on Mar 08, 2008
Http://www.wiserearth.org/group/ChinaMakesCrap/section/main
...want to join a group that is trying to do something about the junk that is being made now?
Posted on Dec 26, 2007
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Jura S7 says fill tank but tank full
The brew unit is damaged and needs to be repaired.
Aug 18, 2014 | Jura Capresso Impressa S7 Coffee Maker,...
Coffee machine problems
Does the pump work? The steam and hot water are from the boiler pressure, but the coffee water circuit is separate and needs the pump.
Does the three way solenoid valve click when you try for coffee?
Why did you change the control box, what was the original fault?
Oct 19, 2013 | Coffee Makers & Espresso Machines
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
'Chugging' noise when trying to get flow of water from steam tube
You must press the hot water/steam button to make sure it is set on hot water. The chugging noise is the pump slowly putting water through the steam boiler for steaming. When you open the steam knob make sure it is all the way open, you will hear the microswitch click when you reach full open(test it out with the machine off). Red light also means heating and low on water, since you are using all the steam faster than it can make it hence the red light.
Jun 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Machine working but not brewing coffee
Hi mate, Check the water - in pipe to ensure there is no blockages/. also check up around the group head to ensures old coffee ground have not been left there and gone hard.
Jul 31, 2007 | EXPOBAR Office Pulser Espresso Machine
Coffee Makers & Espresso Machines Logo
3,006 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
