Question about Lucent Cajun P334T-ML Networking Switch
How to shut down cajun p334t
one of the fans on the module is not working, we have got spares and will be going to replace them with new ones, could some body let me know how to bring down the module and is thier any thing else to be taken care of before shuting down.
regards
nafees
  • 51 Answers
Please shut down all the things then remove the spares and replace it by newer one thats all...
thank you...
Posted on Jan 05, 2008
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
I need a replacement heating element for a Cajun injector electric smoker
Hi, replacing heating elements can be found at amazon, click here and take a look: Save Time Money and Energy with Induction Cooking. I hope this helped you. Have a nice day
Oct 21, 2010 | Bruce Foods Cajun Injector Creole Garlic...
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
When i shut down windows xp, it goes through all and the hard drive shuts down but the cpu fans and coooler fans keep going, then i cannot switch it back on unless i reach to the back of the computer and...
It seens like a motherboard or power supply problem.
If you have a spare PSU, replace it with the current computers PSU. If you don't have a spare, you can always take one from another computer.
If the problem is still showing up, then the motherboard may be defect and will have to be replaced.
Sep 22, 2010 | MSI K9VGM-V Motherboard
Vgn-cs26m will not start,boot into windws and shuts down
kevin,
Is this the pink sony vaio? Looks familiar . . .
The problem with this model of sony vaio is the fan that's why it keeps on shutting down after a few minutes. If you notice there is no activity on the internal fan. The internal fan and heat sink is on the same module.I have already replaced the fan on one of this models and its now working just fine.
just look for a spare fan on ebay . . .
hope this helps . . .
Apr 05, 2010 | Sony VAIO VGN-CS260J/P Laptop
I just had a new motherboard put in my emachine (struck by lightning) and it worked for about a week but I would have to turn the switch off in the back of the cpu after shutting down to get it to turn...
Good day sir, Hi! my suggestion is to swap out first your power supply box, after the lightning, it may have been damage, then try new memory modules, if you have spares swap it with your pc.
Oct 13, 2009 | Computers & Internet
Asus a6tc laptop last few weeks it said no memory i it shut down at night , start up next day hear fan black screen, backlight ok and inverter ok , can you please help, peter
I think you should test your RAM module. If cleaning its edge connector with soft eraser doesn't work. But do this when unit is completely shutdown and no other power source is connected to it. Test the ram with a good spare module if this boot the system youre opt to buy a new one.
Apr 27, 2009 | ASUS Computers & Internet
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Lucent Cajun P334T-ML Networking Switch Logo
159 people viewed this question
Top Lucent Computers & Internet Experts
D. E. Hev
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
