Question about Body Glove Fellowes Earglove Mobile Phone Headset - RETAIL Headset
Phone unlocking my phone is of the model RD 2530 and it has been locked .plzz help me. i have tried the default code 0000.but that is not working.
0 characters
1 Points
Security code
Did you forget your security code ? .If it so means try to unlock your mobile with default code "0000" or "1234" .If it doesn't work means get the Master reset code for old model Nokia mobile from the site Unlock Free com ..After getting the master reset code you can reset your mobile current security code then you can assign a new one.
Jan 21, 2014 | Nokia Bluetooth Headset BH-700 for all...
I forgot my phone s seciruty code,IME 355549/01/783290/50534888,MODEL;6020,COUNTY BOTSWANA
You can try 1234 or 0000 these are default code for Nokia Phones..If these code not work,get the Free master reset code from the site and reset the Nokia 6020 from security lock.
Sep 28, 2012 | Nokia Handsfree For 6020, 6101, 6102...
Nokia 6162 codes
1. Switch your 6120C off and then on again using the power button on top of the phone. A "Lock Code" screen will appear if the phone is locked.
2. Enter your lock code using the number buttons. The default code is "12345." If you enter the wrong code five times in a row, the phone will ignore all entries for five minutes, after which you can try again. See Tips for more information.
3. Press down the "Scroll" key. The phone will unlock with the right code, enabling you to make phone calls and send messages.
Aug 19, 2012 | Nokia 6161 6162 6650 fold 7205 Intrigue...
Cant get car kit to pair with my mobile asking for code
the bluetooth default code is often a 4 digit number 0000 or 1234 if that does not work - post back the exact make and models of the phone and earpiece and I will try and find the user manual where it may mention the default code used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Motorola Mobility Bluetooth Hands Free...
I need an unlock code to connect to my phone
The unlock code for the motorola h3 bluetooth headset is set to 0000 by default. I don't think there is a way to change it so your code should still be 0000.
Apr 22, 2009 | Motorola Mobility Bluetooth Headset H3...
Restrictive code
try 0000
if you never put a lock code into the phone, it should respond to the factory default. check with your carrier for the default code if its not 0000. the manual also will usually tell you the default code.
barring that, you might remove the sim card, reset the phone (see the manual), then reinsert the sim card and reboot.
if you installed the card with the phone plugged in (some units will stay alive with the charger connected) you could have damaged both the card and the phone. try the card in the original location to see if its corrupt.
good luck
Feb 01, 2008 | LG C1300/L1200/4010/4050/L1150/G4015...
Pairing my bluetooth with my chocolate
I wanted to answer this for anyone else who found this question using a web search. The answer is 0000 (four zeros) when asked for the pass code. It's the default code. And your lock code (until you change it) is by default, the last four digits of your phone number i.e. 555-444-5555 (5555 would be your code)
Jan 13, 2008 | Headsets
Body Glove Fellowes Earglove Mobile Phone Headset - RETAIL Headset Logo
14 people viewed this question
Top Body Glove Headsets Experts
Brian Sullivan
Brian Sullivan
Are you a Body Glove Headset Expert? Answer questions, earn points and help others
