Back to:
Tags:
Gateway FPD2275W  LCD Monitor
No power (by 14 users)
posted by ndubuisi on Dec 12, 2007
no power
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by paulie444, posted on Jul 07, 2008
no power at all, light doesn't go on.
Comment by djhouseblend, posted on Jul 05, 2008
I have the same issue w/ 2 of these. Anyone have a solution?
Thank you,
Neal
Comment by sgg1998, posted on Jun 26, 2008
no power lights at all. is there an internal fuse that can be replaced?
Comment by Eskapismus, posted on Jun 19, 2008
My crappy Benq stopped working too just 10 minutes ago. I just can't turn it on again. Not light no whatsoever. It looks like it wouldn't get power ar all. Any suggestions on what to do?
Comment by Pono K, posted on Apr 08, 2008
Some problem. However I had a power surge and the monitor powered off. I hit the power button and nothing. When I played with the power cord, the power light came on then off again.
Any suggestions on whats wrong?
Solution #1
posted on Jul 20, 2008
Not Rated (0)
mhigs
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
check your horizontal output..if its ok check the regulator, diodes if shorted change it with disame value or part number. try to measure the B+ make sure that is more than 200V DC.
By: Quarquee;-)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no power:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Gateway FPD2275W (Black) LCD Monitor
needs new hardrive and possible memory
gateway lcd monitor fpd1530. unit shuts off in one second...
Why does the window slowly roll down to close as opposed...
my computer screen just goes black whenever im playing a...
I can work with this monitor with a sun light but is a...
13 Other Users Have The Same Problem - Continued
Comment by Brian Walker, posted on Apr 02, 2008
Hi, My picture just collapsed and the power light went out. The mains lead and the surge fuse on the main board are both ok, there are no visual signs of damage but there is a ticking sound which only stops when the mains lead is pulled out no matter which position the on/off switch is in. The CRT cathode heaters are NOT lit, so could this be a Low Tension problem?
Comment by anm71, posted on Feb 19, 2008
I have the same problem, no light in the power switch. Not even the orange light.Please help.
Comment by lastcall, posted on Feb 14, 2008
no power on compaq 1701 flat panel monitor
Comment by KeithB79, posted on Feb 14, 2008
I have the same problem. My screen flashed white for a second then the monitor shut off. The power light doesn't even come on. I tried changing the power cord with an identical model, still no luck.
Comment by Guest, posted on Jan 29, 2008
no power....same as others. Took monitor to be repaired. I will write again when they find the problem.
Comment by Guest, posted on Jan 23, 2008
same problem here. the monitor is about 4.5 years old. woke up this morning and had no power. at first, i could wiggle the power cord on the monitor end (slightly pulling it out) to restore power. it then powered off in about 5 seconds and it has no power at all. it's plugged in, and i tried switching cords. nothing. not even an orange light.
is it an internal short? this sucks. 300 dollar.
Comment by nerd freek, posted on Jan 06, 2008
no power at all the led power light dosent turn on not evan the orange light gose on for power saving. and the screen has no backlight and dosent show a picture
Comment by Guest, posted on Dec 15, 2007
no power when plugged in.
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
