Question about SanDisk Sansa E280 MP3 Player
Dead e280 When my battery was running low I attached it to my laptop via the USB cable.  While it said 'Connected', it didn't appear in Windows Explorer.  I unplugged it, it said Disconnected, then it shut off.  I can't get it to turn on, even if if plug it in to my laptop.  Pressing the On button does not get it start up, whether or not it is plugged in.  Is it dead?
    Scholar:
  • 155 Answers
Remove the battery from the player this will not void the warranty of the player. Readjust the battery position and hook it back up to you player and turn it on. If it turns on connect the player back to the computer and charge it for 4 hours.
Posted on Dec 14, 2007
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
Won't print...say's the printer is not-connected.
Try a new USB cable and switching the cable to a different USB port on the laptop. Check if a known working device will work on the laptop. Make sure that you aren't getting a low power situation (low battery, battery not charging properly). If the power adapter is unplugged, see what happens when the computer is attached to the adapter and getting power from the socket.
USB ports can be shut down for power savings so double check that your computer isn't doing this. (This is an advanced portion of the power savings settings and can be found via the Screen Saver Panel in Windows.)
Check the computer's hardware (Windows Device Manager) to check that the USB ports haven't been disabled by a driver problem or any other issue. Control Panel, Device Manager and scroll down to the USB device controller (Windows)
(the most common problem is the USB cable causing an issue.)
Apr 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Connecting to my PC
change the usb mode in the settings menu to msc. if u hav trans. files to it thru win media alredy, delete the music' but NOT THE MUSIC FOLDER SYSTEM WILL NOT BOOT IF NO FILE.
Dec 27, 2008 | SanDisk Sansa E280 MP3 Player
Camera and PC don't talk to one another
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 26, 2008 | Canon PowerShot S1 IS Digital Camera
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
SanDisk Sansa E280 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
