Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Cyan cartridge not working
My printer said my cyan ink levels were low when I hadn't printed more than 3 full colour pictures. Now, it says that the cyan cartridge is not there.
Please help.
  • Confused1234 Dec 13, 2007
    Thanks, but I live Sri Lanka, and power failures are very common, so the date/time resets almost every day.
  • desi35 Dec 27, 2007
    I was always turning the printer off from the power source and all my levels went empty even though i had not printed a single page of color. what a crap printer.
  • 4 Answers
This is desi35 i finally found a simple solution to that problem. each ink cartridge has optical window where the sensor sees the ink level. what you simply do is put a small peice of paper in front of the little window so the sensor thiks u have a full cartrigde. so this solves this problem and saves your life when you essay is due in the morning and all you wnat to do is print in black. later
desi35
Posted on Dec 31, 2007
  • 832 Answers
You have to replace the cyan cart with a new one. error should disappear.
Even though you didnt use cyan the machine needs some ink to keep the noozles wet. Therefore machine does some automatic cleaning cycles which consumes some ink.
BTW: did you program the date/hour settings? Do so and do NOT disconnect machine from constant power, because data will be deleted. machine will do its cleaning cycles about every 2 weeks. otherwise it will do the cleaning everytime its powered up!
Posted on Dec 12, 2007
2 Suggested Answers
n25an
  • 622 Answers
SOURCE: want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
Posted on Dec 21, 2009
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
Want to print only in black
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Colour on DVD disk seems to 'run'
For optimum printing results change your cartridge not long after the printer is reporting low ink levels.
Printer cartridges print in CMYK (Cyan, Magenta, Yellow & Black)
Aug 21, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Everytime I change my print to grayscale it prints in pink
Not knowing what sort of printer you have it's hard to pin-point exactly what the issue may be. Taking an educated guess I'm going to guess that you are using an inkjet of some sort. These printers will often use a combination of the cyan, magenta, and yellow inks to make black and shades of gray, and it is possible to get pink instead of gray if the cyan and and yellow are to low to provide a mix to produce gray. Try new ink cartridges to see if that makes any difference...some printers, like DesignJets use individual cartridges for each colour, and most small printers use a combination cartridget that contains cyan, magenta, and yellow ink in different reservoirs in the same tank.
If you are using a printer that doesn't require both the colour cartridge and the black cartridge in to function, try pulling out the colour cartridge and printing in grayscale. Most printer drivers are designed to recognize the fact that the printer only has the black cartridge in it and will automatically make the necessary adjustments.
Jul 27, 2009 | HP Office Equipment & Supplies
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Cyan ink was full - now it's empty a day later?
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Aug 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
191 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
