Question about Pioneer DEH-P6900UB CD Player
Face not clicking on
Hi, just recently I have found that the face for my car stereo no longer clicks on to the unit, it still functions but i can only see the display when i press and hold it in. I think I may have broken something on the back, can I get this replaced without getting a new face for the stereo? thanks
    Sergeant:
    Champion:
  • 362 Answers
It sounds like you broke the latch built into the player, but just in case you didnt take the face off and the side that goes in last in the player look for a clasp and see if you can move it with your finger if not you will have to clean it it is supposed to move back and forth without sticking. if no clip then its broken. and just to get by if its broken wedge a small peice of paper between the face and the radio. to hold it in place so the display works, until you can find the part at pioneer.
Posted on Dec 12, 2007
Faceplate display only functions when you touch a knob or button
THE FACEPLATE HAS LIKE SOME PINS WHERE IT MAKES CONTACT THE FACE PLATE WITH THE STEREO BODY WITH A COTTON AND SOME ALCOHOL CLEAN THE CONECTOR THE ONES THAT ARE IN THE STEREO BODY AND THE FACE PLATE BUT WHEN YOU MAKE IT MAKE SURE THE CAR OR FACE ITS TURN OFF
Nov 02, 2013 | Alpine CDA-9831 CD Player
Kenwood car stereo face got wet and now won't work, how do i fix it?
If the unit is already fried you may try to soak it in the highest alchol % of rubbing Alcohol for a day then allow the unit to dry Which should happen within a day or so because of the evaporation rate of the alcohol. This should remove the internally locked water and allow for the unit to resume Function without internally shorting.
Jun 06, 2013 | Kenwood KDC-MP242
I have a aiwa CDC x227 car stereo. Have it hooked up, had sound until I accidentally hit the face plate button. Since then I have no sound. Any suggestions on how to get the sound back?
hi, you may have caused an upset to the data flow from face to main pc board. try disconnecting the unit from the vehicle for a day, then reconnect it the next day. or find the reset procedure for your unit, it will either be a small micoswitch behind the face, or a sequence of holding down some switches to activate the reset function. if the problem persists then the unit mite have a cracked main pc board, a faulty face unit, or the mute function is continuously running. to solve these faults you will have to consult with a technician.
May 25, 2012 | Car Audio & Video
My facebook friend request blocked plz help
Hi and welcome to FixYa!
The face of Facebooks pages has changed some recently.
Sign into your FB account.
Click the 'account' tab on the top right.
Click privacy settings.
Scroll to the bottom of the page and you will see manage your block list. Click that tab.
It will have a list of names of people you have blocked. Click the 'unblock' link next to the
persons name you want to unblock, confirm and they will no longer be blocked.
Hope this helps!
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Sep 04, 2011 | Facebook Apps
Stereo face plate does not turn on
Hi. Locate the connector on the rear side of the plate and clean it with soft towel (and a drop of acohol), so the contacts are shiny. Try the same on the unit. There is also usually an reset pinhole on the face of the unit when the face plate is not on it. Try to locate an press with something thin.
Dec 21, 2010 | Panasonic CQ-C8100U CD Player
A problem started with my Panasonic CQ-C9700N car stereo recently which involved the complete facia powering off. However the stereo would still work in the mode it was left in. Every now and then it would...
if im not mistaken, that model has a detachable face plate. What happens a lot of the time is the connections between the face plate and the unit get corroded. Take the face plate off and (with fine grit sand paper) lightly scuff the electrical connection clean on both the unit and the face plate. It also doesn't hurt to use a little dielectric grease before you reattach it... this method has work several times in the past for me... Hope this helped!
Apr 29, 2010 | Car Audio & Video
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
Apr 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
Alpine 7995
sir check the face panel of your car stereo and see if fits correctly and if you have contact from the last owner of the stereo then call him and ask him if he experience about this
Oct 25, 2008 | Alpine CDA-7995 CD Player
Pioneer DEH-P6900UB CD Player Logo
78 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
