Question about HP LaserJet 4050tn Printer
Printing European characters from VMS on HP Laserjet 4050TN
Any idea what I have to add to the VMS Device Control Library to be able to print these characters? (Currently they appear as space when printed from VMS, although OK from Windows).
Ascii values & characters:
192 à 224 à
193 á 225 á
194 â 226 â
195 ã 227 ã
196 ä 228 ä
197 å 229 å
198 æ 230 æ
199 ç 231 ç
200 è 232 è
201 é 233 é
202 ê 234 ê
203 ë 235 ë
204 ì 236 ì
205 í 237 í
206 î 238 î
207 ï 239 ï
209 ñ 241 ñ
210 ò 242 ò
211 ó 243 ó
212 ô 244 ô
213 õ 245 õ
214 ö 246 ö
215 œ 247 œ
216 ø 248 ø
217 ù 249 ù
218 ú 250 ú
219 û 251 û
220 ü 252 ü
221 ÿ 253 ÿ
Any help welcomed,
Thanks,
GTBarb
  • Galen Tackett May 11, 2010
    GTBarb,
    Do you still have this problem? If so, can you tell me what versions of OpenVMS and Decprint Supervisor you are using?
    You also need to check the printer's firmware version. Quoting from the HP DECprint Supervisor (DCPS) for OpenVMS System Manager’s Guide:
    To use an HP LaserJet 4000 or 5000 printer from DCPS, the printer must
    be running a minimum firmware version of 19980714 MB3.68. To use an
    HP LaserJet 4050 printer, it is recommended that the printer be running a
    minimum firmware version of 19991030 MB6.30. Earlier versions of firmware
    may cause problems such as misprinted or missing characters when using
    the DCPS ANSI translator, especially when printing jobs with landscape
    orientation or NUMBER_UP. This firmware version number is displayed as
    Firmware Datecode on the printer’s configuration page.
    If your printer is running an older version of firmware, contact HP and request
    the proper version. The new firmware will be sent on a SIMM to be installed
    in your printer.
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
  • 25 Answers
SOURCE: My HP laserjet p2015n suddenly stopped printing.
You need to replace the formatter.
Posted on Jul 16, 2009
Evildice
  • 222 Answers
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Posted on Sep 24, 2009
nonontech
  • 4737 Answers
SOURCE: no printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Posted on Jun 29, 2010
printerman40
  • 170 Answers
SOURCE: When I am printing to my Laserjet 1320 in duplex
I believe on this particular model if you pull the try out and look at the top inside the tray area, there is a kinda bright green lever that you push in to open the duplex area. open the duplexor and look inside to see if something is stuck up in there. and you might want to get some rubber rejuvinator and clean all the rubber rolls you can see in the entire paper path... hope this helps and if so please mark as FixYa!!
Posted on Jul 16, 2010
Hp laserjet 4050tn error 79.4165
Every time I try to print I am finding it starts off fine and about half way through the page it stops with the error 79.4165. I remove the two pieces of paper and re start and it says ready again only to repeat the same problem. I was wondering if anyone can suggest what to do.
Thanks,
Jacqueline
Jan 10, 2013 | HP LaserJet 4050tn Printer
Pcl XL ERROR ILLEGALMEDIASIZE
When printing from Adobe XI in Windows 7, ensure "Choose paper source by PDF page size" is unchecked, in the File/print dialog box.
Aug 17, 2012 | HP LaserJet 4050tn Printer
Cant print 4x6 cards on HP LaserJet 4050tn
Try opening the rear door and let the cards deliver in the back instead.
Jul 26, 2012 | HP LaserJet 4050tn Printer
I have a HP WINDOWS 7 64 BIT laptop...just purchased a HP 4050TN laserjet Can't see printer if connected to wireless router OR if I hardwire between laptop and jetdirect 600N adaptor on printer
You need to connect the printer with a cable to the wireless router. Then you must enter the printer menu and set an IP address, subnet mask and gateway corresponding to your NAT network or switch the DHCP option on (e.g. to get them automatically from the router). I suggest you to enter them manually if you are not going to switch the printer every day. Then in Windows 7 you must go to devices and printers, select Add printer, select local prinet and choose TCP/IP port from the list. After clicking next you will be asked for the IP address of the printer, you fill the one you entered in the device menu. Next you will be asked for the printer model and you must select it from the list or show a location with the driver. Click finish and a test page will be printed. Hope this helps. Alex
Sep 13, 2011 | HP LaserJet 4050tn Printer
HP Laserjet 1200 prints garbage when printing pdfs
it may be you have a virus in your computer
Mar 25, 2010 | HP LaserJet 1200 Printer
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
You can now print from any computer on your network
Sep 02, 2009 | HP LaserJet 4050tn Printer
4050tn paper tray setup
This is specified by the print driver. Go into the printer configuration or print properties of you have a windows box, and set the trays there - accessories or paper tab.
Apr 10, 2009 | HP LaserJet 4050tn Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
HP LASERJET 3700N - PRINTING PROBLEM
I'm not sure what you mean by "not printing on paper, the image area is shifting". What are you printing on?
Have you tried uninstalling the device drivers and reinstalling them? This may clear any software quirks caused by conflicting devices or user settings.
Feb 08, 2008 | Computers & Internet
HP LaserJet 4050tn Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
