Question about Fujitsu 18C1 Air Conditioner
Fujitsu Reverse Cycle Air conditioner problem
The two "radiators" on the inside "head unit" on my air conditioner are running
at different temperatures. While the one is freezing cold when in COOL mode, the other is hot!?
Had an air-con guy come out who suspected the gas may be low. Charged the system. No good. Same Same.
Another guy came and suspected a valve that would cost around $600 to repair. We found the two valves in the unit that sell for around 25-50 bucks.
That tells me it's either extremely hard to replace or I'm being ripped off.
Anyone out there with any news?
Thanks, Roland
  • Andrew Smith
    Andrew Smith Jan 11, 2018
    Hard to replace. Not only that but very time consuming. Although it sounds like it may possibly be the valve control and not actually the valve but without seeing the system there is no way to say. It could also be a restriction somewhere ie. Kinked pipe or something got in the system on install. Possible that it was not properly evacuated.
  • 235 Answers
Sounds like your 4 way valve failed or something electrical is not allowing the power the valve needs to reverse. You need to get someone who knows ductless systems to look at it.
Posted on Jan 12, 2018
    Visited the website for 30 consecutive days.
  • 434 Answers
Those 2 guys that come out don't know anything about ac
So sound like you have a ductless split system .was this newly installed or was it running fine before .If unit was running fine before and now giving issue you need someone who know what they are doing and look at it .
The guy that add charge to the system may have caused the issue to get worst
Posted on Jan 11, 2018
  • Michael Youngman
    Michael Youngman Jan 12, 2018
    I'm a licensed HVAC contractor in California for 23 years and have installed many Fujitsu ductless systems. Because you have a different opinion does not give you the right to question my ability. If you're going to work against people who donate their time, go somewhere else. Should work together, not against
    Problem Solver:
  • 9 Answers
Posted on Dec 15, 2007
How can I get a Manual for a Fujitsu Split system reverse cycle air conditioner. Model - AOT7RSCC
You can call Fujitsu and ask them for a manual. They might email you or give you a website where you can download it.. if not then call your local authorized Fujitsu dealer/distributor like RSD (refrigeration supplies distributor)
Mar 03, 2015 | Fujitsu Heating & Cooling
I have a fujitsu reverse cycle aircon AOT36RCD3L had power switched off for 5 hrs now compressor is not working self diagnosis is saying E 100 inside fan is still working what do you do to get it working...
Hi Mark,
I hope the following link is of some help for you?
Good luck
Feb 05, 2015 | Fujitsu Heating & Cooling
Our fujitsu reverse cycle AC is leaking water at bottom left hand side of the internally mounted blower unit
Your drain for the inside unit is stopped up and the water condensate that drips off of the coils when the AC is running has no where to go, so it drips off of the collection channel and over flows to the bottom of the air handler, gravity dictates the place where it leaks. You are going to have to unstop the drain.
Feb 01, 2011 | Fujitsu 24C1 Air Conditioner
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Hitachi model number unknown !! (faded 0ff unit)
dirty unit and need for cleaning
clogged up expansion valve
defective fan motor
deffective air sensor
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu reverse cycle split wont blow cold
same as car aircon, but uses different kinds of freon. check first the thermostat setting, may be it set too high. set it to 20'c. if still not cooling, check wiring on ACCU, check capacitor too.
Jan 18, 2008 | Fujitsu 18C1 Air Conditioner
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
241 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
