I programed my cable box, tv. but i can't get my tv to go on tv/video.
i can't program my dvd player either. i can't find the codes for coby dvd,
player. HELP!!!!!!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
normaly press and hold the device you wish to program till the light stays on then enter code if the code is a valid one the light should go off and then you may be able to turn off tv if not repeat steps and use diff code here are the codes i know of for daewoo tv 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058 0017 0010 0126 0018 0127 0019
A: power on the device you want to controll B:press and hold the (set) keyand press the device key at the same time.. C:the LED will light at that moment then release the pressed keys.. D:PRESS THE SET KEY AGAIN THEN RELEASE IT. THE REMOTE ENTERS THE QUICK SEARCH MODE AND THE LED KEEPS FLASHING... E:Point the remote at the device,then press the power key.see if it reacts
Unfortunately, Trisonic dont publish their codes on the web. Call Trisonic toll free at 1-800-TRISONIC. I am sure the operate on a
Mon-Fri basis probably 9am-5pm. It is the only way to get your codes.They are very helpful. When you get
your code you will need to push and hold the SET button first, then
push your device button (TV, DVD, etc)as you continue to hold the SET
button. I red light will appear on the front of your remote and it will
remain on until your enter your device code. Enter your code and hit
the power button to test your device.
This is the best and only way to get your Universal remote code. It
saves you from having to buy another remote or spend any other money.
i lost the manual for TS RC 466 anyone has a solution
any set the comtrol for may tv durabrac
i need the codes for a universal trisonic ts-rc466 remote for a apex television
Control Codes for 2 in one video Cassette Recorder and DVD Player
universal remote programing instructions
trying to program it to control television, dvd player and convertor box
