Question about Intel D865GBF Motherboard
Ram can works dual channel
I have computer intel 865gbf 2.4 ghz
i but 2 ram 512mb ddr400 one in the socket (a) and ather in the socket (b)and is not worck dual channel i go in the bios i see and it is work onli signel channel and ddr333 haw can i fix the problem
    Sniper:
  • 51 Answers
You need to make sure your ram is identical.....for example if you have one single/sided and one double sided but are both equal in capacity still may not work.......also you could be using wrong memory slots double check your motherboard manual and ensure you are using correct memory slots for dual channel operation...however memory pair mismatch is most likely your culprit
Posted on Dec 12, 2007
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
I need to upgrade my pc ram, pulled the ram and infineon is the manufacturer, they no longer make ram so how do I know what other ram I can put in my motherboard, got number from stickers on the...
Look for labels on the RAM: PC100 or PC133 or DDR266 or DDR333 or DDR400 or PC2100 or PC2700 or PC3200.
Since you cited 'DDR400', you need to purchase 'DDR400' RAM.
Any sales-person in any computer-store can sell you 'DDR400' RAM.
Feb 03, 2011 | Abit NF7-S (V2.0) 400MHz FSB nVidia...
I have Intel Orginal 845GVSR motherboard with 2.4 ghz Processor and 256 ddr Ram. Can I increase my Ram to 1 gm with 400 fsb speed
Yes you can, the speed will be increased approximately more than 50%. There's also advantage if you can install two 512mb, which you'll see it as "dual channel", sometimes this is better as per the system configuration. Good luck. Thank you for using FixYa.
May 14, 2010 | Intel D845GVSR Motherboard
Asus p5gl-mx 915GL chipset dual channel ddr400 no display
try to change your RAM random access memory
Regards
manish
Mar 25, 2010 | Intel Asus P5GL-MX 800MHz FSB 915GL...
If I unstall DDR400 memory as as follows: DDR1 & DDR3 : 512MB each DDR2 & DDR4 : 256MB each making 1.5 GB in total, will dual channel technology be activated?
Definitely not. Dual channel technology requires that the 2 RAM modules installed in each bank be of the same capacity, data rate, & even better be from the same manufacturer.
Oct 30, 2009 | Gigabyte GA-8I915G Pro Motherboard
RAM not found as 2x512MB
Are you finding these number when you go into your bios or from a program such as CPU-Z? If you are using good quality DDR400 memory, it should be posting with the full amount of memory available. You are using the correct slots to get dual channel, but you may want to try slots 1 & 2 or 3 & 4 to see if it will post with the full amount of memory as single channel. You may also want to have a friend try the memory in their computer to see how it posts, you may have some bad memory.
Apr 05, 2009 | Intel D865GBF Motherboard
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
New ram makes my pc freeze
Many motherboards when booting from dual sockets wish for ram either of same manufactuer or same capacity per stick
Jan 14, 2009 | Biostar GEFORCE 6100-M9 Motherboard
URGE AYUDA PROBLEM AS CON VIDEO
hay una ocasión que el monitor está fallando… redownload e instala los conductores para esa tarjeta video… tenga muy cuidado que usted esté instalando el apropiado para la tarjeta y el sistema operativo Roberto Clasifique por favor esta solución
Sep 01, 2008 | Intel Motherboard
Intel D865GBF Motherboard Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
