Question about HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
Compaq presario 158793-001 motherboard
Have just removed motherboard and fixed loose dc. jack plug. rebuilt pc very diligently following repair manual. when battery is inserted power on led ok, hard drive works, cd drive works floppy disc drive works but no back light on scree and cooling fans not working. After connecting charger still same response but no charger light or battery state leds showing. is there a testing method for motherboard or circuit diagram to trouble shoot
mother board ???
please help
mike3.
I have a compaq 1247 laptop. I had problems after I took it apart. It was very difficult to get the processor chip back in properly, the little clip has to "snap" in place to hold the chip firmly in the socket. That solved my problem.
Posted on Feb 24, 2008
Hey Mike
Go back and check the fine cabling that connects LED indicaters to motherborad. There's got to be a small cable you forgot to plug into the board to feed back poer state. Take your time and check everything twice.
Posted on Feb 18, 2008
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
Compaq presario cq61 will not stay turned on.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Compaq Presario CQ61 AC Adapter 65Watt 18.5V 3.5A
Replacement Compaq Presario CQ61 AC Adapter 90Watt 19V 4.74A
Nov 21, 2012 | HP Compaq Presario F730US Notebook
The power plug is loose and i cant get a good connection
You need to replace the dc jack. This could be a solder on the board type or plugged into the motherboard. Either way, the part cost is only about £4.00, as long as you are capable of dismantling and soldering it is a cheap enough repair
Jan 28, 2011 | HP Compaq Presario CQ70-120US Laptop
No light when charger connected to laptop.
You do not have to resolder the connection, the dc jack is attached to the motherboard via a cable and plug. You can purchase these on Ebay for under 20 bucks. Below is the link to the disassebly guide that will assist you.
This link here is for the DC jack...
http://cgi.ebay.com/HP-G60-CQ60-DC-IN-Power-Jack-Cable-50-4H515-001-/110525996737?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19bbdcdec1
This link is for the illustrated guide to removal of the motherboard.
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
Jul 27, 2010 | HP Computers & Internet
Looking for a repair manual. Power jack appears
This is HP Support, and the Service Manual download page for the Compaq Presario V2000 series Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=500508&
Left-click on, Compaq Presario V2000 Notebook PC, HP Pavilion dv1000 Notebook PC, HP Compaq nx4800 Notebook PC - Maintenance and Service Guide.
Page 166, or Section 5.20 details System Board (Motherboard) removal.
(Section 5.4 starts on Page 117)
One example of a place to buy another DC Power Jack,
http://www.dcpowerjacks.net/catalog/product_info.php?cPath=3_4&products_id=121
Information that may help you in replacing the jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
I do this procedure quite a lot. If you find you need guidance, simply state so in a Comment.
Apr 13, 2010 | HP Compaq Presario V2000 Notebook
Dc jack is not working, can I still use a docking
I have seen this problem with many laptops.
What has happened is that the power connector on the laptop has loose solder connections and will not trasfer the power through the jack. Either the jack needs to be resoldered on the motherboard or replaced. This is a very intense repair, because the motherboard has to be removed for the repair.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 15, 2010 | HP Compaq Presario V2000 Notebook
I need to replace AC Power Adapter Socket, Where do I find this to purchase??
you may check follow website find your laotop DC jack and chose a good price one.
http://shop.ebay.ca/items/__HP-Compaq-V2000-DC-jack_W0QQ_kwZHPQQ_kwZCompaqQQ_kwZV2000QQ_kwZDCQQ_kwZjackQQ_ckwZPresario?_trksid=p3286.m104.l1199
how to change the DC jack:
please reference the manual page 3-1, to disassemble all covers.
and replace the DC jack.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
hope help you fix it.
May 19, 2009 | HP Compaq Presario V2000 Notebook
My compaq presario will not power up (no power). I have swapped and tried a different power supply. No luck
Could be one of a few things. I'm assuming this is a presario laptop, not a desktop.
System needs to be restarted - Remove the battery and let the laptop sit a while (30 minutes). Reinstall battery and plug in power supply and see if it works. If not,
Remove the Battery and see if it is charged up (there are a set of green lights on most compaq laptop batteries with a spot to push to confirm the battery is charged). If it isn't charged, you very likely have a bad DC Jack connector on the laptop motherboard. If you apply pressure to the cord which plugs into your laptop (up and down, side to side) at the spot where the cord is connected (back of the laptop), see if the power light, on the front of the laptop, comes on for second. If it does, you can fix this by buying the DC Jack for your laptop model on ebay ($10) and removing the old connector and installing, soldering in, the new connector. This will require you to take your laptop apart. (note: Search the internet for the service manual for your laptop and this will give step by step directions on how to do this.)
Also, I think they do this at Best Buy (Nerd Herd) if you aren't comfortable doing ($75)
If it's not the DC Jack, it's a problem with the motherboard / CPU / Power Inverter or something else, most likely not worth your time to fix. You could sell the laptop for parts on ebay to recoup as much of your cost as possible, then buy another.
If you are slightly mechanical and are looking for a project and don't need the laptop immediately, you could buy the individual parts and replace piecemeal, based on directions from the service manual. FYI - I've picked up a few laptops for next to nothing and repaired this way {Compaq Evo n620c (CPU / DC Jack), IBM T22 (LCD Screen), Compaq M700 (DC Jack)}.
Dec 06, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario X1000 Power Issue
Two things... put your hand on the bottom of it.... is it really hot and second any chance of trying another power cord on that ?. I believe you mentioned you tried that cord on another computer. perhaps use the other cord on yours to test it .
Aug 28, 2008 | Compaq Presario X1000 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan Logo
293 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
