Question about Radio Communications
Positive or negative
Want to charge 2 way radio direct from car cig lighter socket,on the plug, is the shaft positive or is the tip of the plug positive,to suit this type and model of radio. Thanks Tony.
tsuen shing-2way radio, MODEL wt-419
  • greenrider Jan 08, 2008
    Thank-you people,you have made my life just that much easier,knowing I have you guy's to fall back on,great work,Tony aka Greenrider.
  • alan holmes Mar 02, 2008
    Hi
    I have a set of T5522 radios with a drop in charger but have lost the mains lead. I have a universal charger but do not know what the correct polarity setting should be or the voltage to set it at. Can you help?
    Novelist:
    Champion:
  • 211 Answers
It normally says on the case of the radio where the plug inserts. If not, get a DC Voltmeter and carefully read the voltage and observe the polarity of your test. Most radios have a positive tip polarity. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
How do i find lighter fuse
Lighter fuse for corolla is on the interior fuse panel on LHS of dash. It is labeled CIG. And is a 15amp fuse, this is common for them to blow when people plug in charging devices or sat. Radios into them, try using the power point socket in centre arm rest.
Oct 12, 2014 | 2010 Toyota Corolla
Garmin GTM 25 Charger is not charging GPS, but the red light is coming on when plug in to GPS and Cig lighter. Could this be a fuse in the charger?
Unscew the Cig lighter plug silver or black tip part, the fuse in located in there, be careful its sping loaded....check fuse should be a 3 A fuse any Radio Shack should have it or auto store
Sep 22, 2010 | Garmin GTM 12 FM TMC Traffic Receiver...
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
CIGAR LIGHTER WILL NOT CHARGE UNLESS ENGINE
Some cig lighter plugins are wired directly to battery, others are connected to ignition. You can always re-wire it straight to fuse or radio memory wire (Yellow) on cd deck or (Green/Black) from car wiring
Nov 12, 2009 | 2004 Jaguar XJ-Series
Looking for the cigarette lighter fuse
Check all fused related to audio, dome light or instrument cluster. Try plugging a cellphone charger into the socket for cig lighter, if this works then you need a new cig lighter.
The cig lighter is probably part of the circuit tied to radio instrument cluster or dome lights, if any of those are out too, then it is likely a bad fuse or bad ground. Look for corresponding fuse and kill 2 birds with one stone hopefully by replacing the faulty fuse.
If you locate and replace a faulty fuse and the problem persists, you may have a bad ground. This is a bit more involved. I would guess by your question that you will need to have someone service it for you.
Oct 29, 2009 | 1992 Mercury Grand Marquis
Fan blew 12v car fuse
You probably burnrd out the wiring into the lighter or, you burned the contacts in the lighter socket. You can not use an AC fan in a car. A car is DC.
Jul 09, 2009 | Radio Shack 120VAC 4" Fan
Radio and cigarette lighter won't work 1996 Ford Ranger
Read your manual .It tells you were the fuses are.. If you use a test light,the terminal at the bottom of the lighter socket is positive and the barrel is ground.Don,t touch the two,or you will need another fuse. The fuse panel is on the left end of the dash.The cigar is #17 and radio is # 20
Jun 14, 2009 | 1996 Ford Ranger SuperCab
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
Cig lighter, radio, etc wont work after plugging in cell phone to charge
it sounds like you blow up a fuse,check your fuse box,
check your manuel for locations
gl G
May 04, 2009 | 1998 Toyota Camry
1991 s10 pickup radio and cig. lighter shrts out
You need to replace the lighter socket. Both of my 1988 S10's had the same problem after a few years of using my cell phone battery charger in the lighter plug. I replaced it 10 years ago and it has been fine ever since. Something in the original socket wears out and causes it to short out when something is plugged in. Good luck!
Apr 01, 2009 | 1991 Chevrolet S-10
Radio Communications Logo
78 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
