Question about Refrigerators
POWER TRIPPING IN SAMSUNG REFRIGERATOR SIDE BY SIDE
SIR,
SAMSUNG FRIDGE HAVING THYRISTOR SWITCH DAC CONSISTING OF
A MODULE HAVING THREE SEM DEVICES:
1. XSV918/BUV46 PACKAGING-3PIN)
2. 7AM023 (THRISTOR SW 2PIN PACKAGING)
3. XS918/ BUV46 PACKAGING-3PIN)
THE REFRIGERATOR (SAMSUNG REFRIGERATOR MODEL- SRS73DTA) POWER TRIPS AFTER FEW HOURS OF USAGE.
KINDLY ADVISE SOLUTION, REGARDS!
ASHOK
EMAIL me at: ashok.gupta26@gmail.com
  • 1462 Answers
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Posted on Jun 19, 2007
robotek
  • 1512 Answers
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Posted on Mar 21, 2008
SOURCE: lg multi air flow gr-349sqf
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Posted on Apr 01, 2008
catriver
  • 878 Answers
SOURCE: My whirlpool refrigerator trips the main power
Pankaj, Do you have a ohm meter? Sounds like you have something shorting back. First take the meter to the cord. On the end of the cord, you should show no continuity from each male prong to the ground prong on the cord itself. If you show continuity, you have something shorting back. Then I would start with the compressor, Unplug the wires going to the overload and relay, make sure the units unpluged and meter the cord again. If it's ok, then the problem is in the overload and relay. Start there and let me know, if it still showing a short, then we will have to go to the controls, heater, and repeat the process until you find the culprit. Catriver.
Posted on Jun 10, 2008
SOURCE: Hi, The Earth Leakage Breaker (ELCB)
what is elcb
Posted on Nov 16, 2008
Refrigerator plugged in but not running or cooling
Check fuse in the plug use any other working one in the house to test it .
Hope that will help
Dec 05, 2015 | Samsung RS2630SH Side by Side Refrigerator
My westinghous side by side fridge keeps on tripping after every 3 hours .
Probably the result of the compressor being overworked, either because of an accumulation of dust and dirt on the bottom coils or a burned out fan. Both are relatively easy to fix yourself.
I preach the gospel of keeping your refrigerator clean. Accumulation of dirt and dust on the bottom coils can make your compressor build up enormous amounts of pressure in the line and make it VERY difficult to start and run. Clean the coils and while you've go the back off the refrigerator, make sure the fan is running when the refrigerator is running. If not, replace the fan.
Odds are that one of these two simple fixes (which you can do yourself) will fix the problem. If not, you'll probably have to call a repairman.
Mar 17, 2013 | Refrigerators
My refrigerator want get cold,however vents inside the refrigerator freezes. My milk keeps spoiling due to not getting cold enough
The defrost circuit in your fridge has failed. That is why the ice is blocking the vents preventing the cold air from entering the fridge compartment. The circuit consists of the control module that turns off the compressor and powers the heater and when the coil heats up to 40 deg F, the thermostat cuts the power to the heater. It a relatively easy to troubleshoot and repair if you have some mechanical ability and familiar with electrical meters and electrical safety. If not, an appliance repair specialist should be about to diagnose and fix this issue. The typical failures are the defrost heater burning out and if worst case a module needs to be replaced. Hope this helps you.
Dec 08, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fridge and freezer not working - lights are on
YOU ARE GOING TO NEED TO INSTALL A THREE IN ONE BECAUSE YOUR STARET RELAY I KAPUT.
Mar 07, 2009 | Samsung RS2630SH Side by Side Refrigerator
Bizarre Refrigerator Problems
If your voltage is around 117v.you are okay.Any time you lose cold air except the freezer you probably need to check your evaporator thermostat and your heater.
Sep 15, 2008 | Samsung RS2556 Side by Side Refrigerator
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
883 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
