Question about EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard
I want to fit a video card to my computer but I dont know what type to get. I have tried a MSI NX7300 but it would not fit as the socket has a divider in it?
  • nu2dis Dec 12, 2007
    Thank you,
    it has a segmented agp slot?
    Thank you Chad,
    the model is ECS 661FX-m.
  • 259 Answers
Here are the specs for your motherboard it takes AGP 8x Video card
FSB 800
HT CPU Support
DDR 400
Serial ATA
AGP 8X
6 Channel Audio
Processor
Socket 478 for Intel Pentium 4 processors
FSB 800/ 533/ 400MHz
Support Hyper Threading Technology
Chipset
SiS661FX & 964
North Bridge: SiS661FX
South Bridge: SiS964
Graphics
Integrated SiS Real256E Graphics
System BIOS
Award BIOS with 2Mb Flash ROM
Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
Full Support for ACPI revision 1.0 specification
Main Memory
2 x 184-pin DDR DIMM socket support up to 2 GB
Support DDR400/333/266 MHz 2.5V DDR SDRAM
Expansion Slots
1 x AGP 8X/4X slot
3 x PCI slots
1 x CNR slot
Storage
Support by SiS® 964
4 x Ultra DMA133/100/66 devices
2 x Serial ATA devices
RAID0 & RAID1 configuration
Audio
Realtek ALC655 6-Channel audio CODEC
Compliant with AC'97 2.3 specification
LAN
Realtek RTL8201BL 10/100 Mbps Fast Ethernet PHY
Rear Panel I/O
1 x PS/2 keyboard & PS/2 mouse connectors
4 x USB ports
1 x RJ45 LAN connector
1 x VGA port
1 x Parallel port (LPT1)
1 x Serial port (COM1)
1 x Audio ports (Line-in, Line-out, Mic-in)
Internal I/O Connectors & Headers
1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
1 x Floppy connector supports 360K~2.88M Bytes, 3 Mode FDDs or LS120
2 x IDE connectors
2 x Serial ATA connectors
2 x USB 2.0 header support additional 4 USB Ports
1 x SPDIF out header
1 x Front panel switch/LED header
1 x Front panel audio header
1 x Speaker header
CD in header
CPUFAN/CASFAN connectors
Form Factor
Micro-ATX Size, 244mm*230mm
Here is a link to your motherboards manual:
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=392&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Posted on Dec 12, 2007
    Scholar:
  • 54 Answers
Hey nu2dis,
That MSI NX7300 (geforce 7300), is a PCI Express card.
Unless you've got a board that's at the most, 2yrs old, you probably won't be able to use it unless you upgrade.
A good site to look for a card that may fit, is www.newegg.com , or www.tigerdirect.com
IF you post your exact motherboard model, I could tell you what you would need.
But to tell the diff between AGP and PCI,
AGP will be a slot, that looks diffirent then the other slots. (the board will have 2-4 slots that look idential, and those are usually PCI, and then it will have one that's actually set back a bit further, and may even be a diffirent color, if its not PCIe, then it's AGP). ANOTHER thing you have to look for to, is the speed of AGP. Most cards today are AGP 8x. If you're board is say...older then 4 yrs, you prob have AGP 4x, or AGP 2x.
If you're still unsure, post the model of board, and I'll help you out.
-Chad
  • 95 Answers
If it is quite old it may not have an AGP slot in that case you will need to buy a PCI card for it.
I'm having issues installing MSI N210 MD512D3H GC on my AMD based system. System Driver Error 43 what could this mean? I've tried package drivers and most recent drivers with full clean install...
make sure the video card is securely seated and no dust in the socket restart your computer then reinstall the card and the updated drivers if this fails to fix the problem try the card in another computer to see if it works it might be faulty
hope this helps you
Aug 31, 2011 | MSI N210-MD512D3H/LP GeForce 210, (512 MB)...
Can anyone tell me what type of motherboards are on Acer Aspire M3641 desktops? It is written in paint, on the motherboard, only: "Micro-Star" (MSI, I think), N1996 (Australian standard for FCC...
IF, and I stress IF, you decide you simply want to replace the motherboard, get one that matches your processor socket, and be super careful when removing, cleaning, and replacing it.
The question will be, will your new motherboard fit in your case. Simply get one with similar specs as your current one.
most MSI products fit inside of an acer case though.
GOOD LUCK AND PLS RATE THIS POST!!!!
Nov 15, 2010 | Acer Computers & Internet
Msi n9800gt(geoforce)video card problem
Could be your BIOS version doesn't support that grahics card. Try instaling MSI LiveUpdate and flashing your BIOS (LiveUpdate download here: http://global.msi.eu/index.php?func=downloadindex)
If that doesn't help, maybe try another graphics card in the system, see if it'll boot.
Dec 09, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Whats the best cpu for PM8M3-V H
you can change your Processor into Intel Pentium 3.0Ghz, for socket 478 pin type. or intel celeron D 3.0Ghz socket 478 pin type. i would like to let you know that the speed of Computer depend on the processor and memory is for cache only.
Jun 11, 2009 | MSI PM8M-V Motherboard
Type fo Ram and Compatible graphic card
You can look up you mother board on the MSI support website. You wil need to know the CPU  socket type. Download the manual for the board and the RAM and recomendations or in the manual.
http://global.msi.com.tw/index.php?func=downloadindex
Jan 18, 2009 | Intel Motherboard
My problem is that i dont know how to download the sound device . I have MSI computer.But i dont know the type of my sound card .I will be grateful if you help me
If the sound card is in one of the slots you may just take it out and read the brand and model number right from the card. If the sould card is part of the mother board it will not be in one of the slots but be part of the board itself . If that is the case go to the MSI site type in the model number and download the drivers and sound from them or loook up what kind of sound and go to thheir web site.  Any more questions as I know this is not such a complet answer , please write me back.
Jan 02, 2009 | Computers & Internet
Motherboard problem
If VGA or PCI-16 slot is failing along with audio , you can purchase a pci sound card and a pci video card , but the best thing to do it just get an entire new motherboard or machine .
Jul 31, 2008 | Intel Motherboard
Onboard sound card drivers
just download the driver from MSI support website. just provide the model number and what OS you are using.
Feb 21, 2008 | MSI Motherboard 845GEM-L i845GE P4 533FSB...
Multiple display problem
Hello. Your driver software was 71.6MB large. It not only included the driver software but secondary software for you to control & setup dual monitors. The package came with a HDMI connector which is used to connect the HDMI femal port to VGA port, if the monitor does not have a HDMI male port. Currently the reason you can not see your display is because the signal comming out of the video card is set to the other port on the card. Once you switch to the other port you'll have display on your monitor. Open control panel, than open display. Display Properties will open on your desktop. Click settings than click advanced. You should see another tab that reads something like, NVIDIA® nView Multi-Display Technology. (I'm guessing because I only use ATI's software) I can't load your driver software on my current system. The two cards may be different but the software is similar. This Nvidia tab is where you set up your monitor or monitors. Once in this advanced portion for your video card you can set which connector from the video card will display on what monitor. There will also be a ton of settings you can adjust, from color to 3D & other options. You must have an icon by your clock as well that allows you to open the standard display properties or the advanced display properties.
Feb 19, 2008 | MSI NX7300LE-TD256EH GeForce 7300 LE,...
EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard Logo
228 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
