Question about Acer Aspire 5610-4648 Notebook
BIOS setup Acer Travelmate 3210. When I press F2 at startup the laptop just beeps and then continues to load Windows XP. How do I enter BIOS to check Video memory which I need to upgrade to 128Mb. Thanks Ron
  • 24 Answers
Hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Posted on Dec 14, 2007
When I startup my pc I have to press F1 before it starts . I am running windows xp home
This has nothing to do with windows, but is a cmos or bios issue. There should be an error something like, Time incorrect press F1 to continue or F2 to enter setup. Check the error and then press the correct key to enter setup. If the issue is the time, fix the time and date in set up. Most other issues will clear when you exit and save set up.
If you would like more information, please provide the exact wording of the error that you are pressing F1 to continue from.
Dec 14, 2011 | Microsoft Windows XP Home Edition
Tip
Windows XP setup disk says disk not found.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
on Apr 15, 2009 | HP G60-120US Laptop
Icant get my acer travelmate to boot from cd
You need to set the BIOS configuration to boot from the CD.
I'm not sure how the Travelmate enters the BIOS (Setup), it could be the F1, F2, ESC or DEL ket after the ACER logo and before the Windows logo appear on the screen. When the BIOS opens, go to the Config page, set the CD to be the first boot device.
Aug 15, 2011 | Acer TravelMate 722iTX PC Notebook
When i power on my acer aspire 1640 laptop it4 gives a continuous sound for 1 min, then windows xp start.
Press F2 as soon as you see acer logo screen then once you reach the Bios Setup screen Press F9 hightlight YES then hit ENTER key on Keyboard Press F10 then save and exit !
Dec 02, 2010 | Acer Aspire 4315 Notebook
Make sure your scsi disk is turned on refer to manualwhen installing windows xp pro, acer travel mate 290. then states use another partition but comes with the same message one of your disk is damaged...
yes indeed nowadays laptops are designed for windows vista and better versions as these are equipped with SATA harddisks. to install windows xp in these systems u need to change SATA settings in bios which can be done by 1->pressing F2/DEL key during the starting acer empower people screen which v get once v switch on the laptop 2->in the BIOS screen go to MAIN tab by pressing right arrow 3->scroll down till u get SATA mode->press enter .two options ll be available 1.AHCI 2.IDE 4->select IDE and press enter. 5-> go to exit tab and select save and exit 6-> now try installing xp pro!!
Jan 11, 2010 | Acer TravelMate 290 Notebook
Cant detect hard drives during the process of loading xp
Just pres F2 key on startup. Go into bios. In bios find HDD and press enter next to mode. Select IDE mode and press f10 to save changes and exit. You can install XP now. Alternatively you can use USB floppy drive to load SATA drivers.
Let me know if you need assistance on that
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Acer travelmate 3210
Acer Travelmate 3210 is the Series
and in that series your Laptop model is 3212NWXMI
like Acer Aspire 5300 is series and 5320 is the model number like that.
there was no need to update Bios
now in case your laptop is turning on
Please try to start in the Safe mode
and there you shut down your laptop properly and try Restarting in normal mode.
Secondly, If you are well versed with the technology then please
try to reinstall the Windows Xp
and BIOS update is something you should be very careful of.
do not try unless it is MOST required
Dec 30, 2008 | Acer Computers & Internet
Problem on loadind windows xp on hp pavilion dv2000 laptop
Nov 29, 2008 | HP Pavilion dv2000t Notebook
Acer TravelMate 4150LCi
you have deleted one of the windows files similair to boot.ini files, there is a method of repair but too much to type here, please go to this link and follow instructions
Sep 19, 2008 | Acer TravelMate 4150LCi Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Acer Aspire 5610-4648 Notebook Logo
316 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
