Question about Sony PlayStation Portable (PSP) Console
Sony psp i can't see my psp when i usb plug it in turn it to psp mode and open " my computer " but my system tray can see hardware plugged in
    Problem Solver:
  • 18 Answers
You can try a few things.
Click Start, then right click my computer and click "manage". Click Disk Management and look in the menu on the right for your psp "It should resemble as disk around the same size of your Memory Stick"
Once you've found your psp, right click the icon under "volume" and choose "change drive letter and paths"
Choose another letter, "P:" in this case. Go to the "My Computer" folder, right click and choose Refresh.
That should solve it, but there might be another solution as well that involves the Device Manager.
Try different USB ports on your computer if this post doesn't work
Posted on Dec 12, 2007
How can i download pictures to psp
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.....
hope this helped..good day..
Dec 20, 2010 | Sony PlayStation Portable (PSP) Slim...
About music
conenct the PSP to USB and then set it to USB mode.
access your "my computer" then clcik on the PSP icon on your my computer screen
you will be able to see folders in there, one is music, just copy the music file from your computer then paste it in the "music folder in the PSP.
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
Tip
How to remove virus off sony psp
<span> <li> <p>Connect your Sony PSP to your computer via the USB cable.<br /></li> <li> 2 <p>Power on the gaming device and in a moment the computer will state it has detected new hardware.<br /></li> <li> 3 <p>Open "My Computer" ("Computer" in newer Windows versions) and look to see what file abbreviation your PSP is given.<br /></li> <li> 4 <p>Launch the anitvirus software you have on your computer. You can <span>download</span> several virus-scanning software products for free online from www.cnet.com.<br /></li> <li> 5 <p>Select the PSP drive to scan for viruses. When the scan has completed, it will display any viruses it has found on the device. Select "Remove" and the viruses will be removed from the Sony PSP.<br /></li><span><br /><br /></span></span>
on Nov 24, 2010 | Video Game Consoles & Games
How do I put photos from my comuter onto a 2gb sony memory stick
  2. Turn on the PSP.
hope this helped..good day..please vote...
Dec 11, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How to use the usb to down load music from my computer
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how much music you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  7. If there isn't one already, create a folder called "MUSIC" inside the "PSP" folder.
  8. Drag and drop image files into the "MUSIC" folder just as you would save files in another folder on your computer.
Nov 28, 2010 | Sony PlayStation Portable (PSP) Slim...
I don't know how to load photos from my PC to my PSP
To load photo on your PSP follow these steps.
1 Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
2 Turn on the PSP.
3 Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
4 Scroll to the "Settings" icon on the home menu of your PSP.
5 Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
6 If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
7 If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
8 Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
9 Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Aug 25, 2010 | Sony PSP-3000 Black Console
My pc does not read my psp, how do i fix it.? do i need to install a psp driver.? where do i find such driver for free.?
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT " mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
Apr 02, 2010 | Sony PlayStation Portable (PSP) Slim...
How do i set up my psp to my pc i have no manual
First, you need a Micro-USB to USB cord (plug the Micro-USB end into the PSP, and the USB end into the PC's USB port). If you don't have one, you can get it from Ebay or Amazon, just search 'PSP Transfer Cord' or something like that. After you've plugged it in, put your PSP in 'USB Mode' and then your computer should say 'Found New Device' and then 'Installing New Hardware' overtop of an icon in the tray. After it's installed successfully, go to my computer, and click the letter of whatever port you plugged it into (i.e., 'Drive F'). You should see some folders saying 'MUSIC', 'PICTURES', 'VIDEO', etc.
***NOTE: If your computer doesn't do anything when you plug your PSP in USB Mode into it, try using another USB port, or try going to My Computer to see if it's already there.
Feb 16, 2010 | Sony PlayStation Portable (PSP) Console
How to put music on psp?
You need a memory card for your psp, as well as a usb cable....plug the usb into your pc and go to system settings in the psp and turn on usb mode (your computer should recognise the psp as an external drive in the MY COMPUTER window) open the drive. Open the file called PSP and look for a file called MUSIC, open it then copy your music files to this folder......If you do not see a psp file on the memory stick duo just save a game to it from the psp.....this will create the folders you need, then repeat my instructional...Good Luck
Oct 02, 2009 | Video Game Consoles & Games
Psp
Follow this steps to transfer music on PSP:
  2. Turn on the PSP.
  6. Create a folder called "PSP" on the PSP Memory Stick (if there isn't one already) -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. Create a folder called "MUSIC" inside the "PSP" folder.
Hope that helps........
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
