Question about D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k)
D-link router ive got aA D-LINK ROUTER WHEN I HAVE IT ON IT RUNS PERFECT BUT AFTER ABOUT HALF HOUR IT STOPS WORKING MY MODEM IS OK AND IVE UPDATED THE DRIVERS FOR THE ROUTER BUT STILL THE SAME WHAT CAN I DO
  • 32 Answers
I believe it is a setting on the router.. There should be a timeout setting that needs to be altered. I cant tell you which setting, but this was happening to my network as well.. I used to be a Dlink fan, but have since moved to Linksys.. If buying a new router for you is an option, go for the Linksys WRT54G/GL/GS series. Sorry I cant be of much more help.
Posted on Dec 31, 2007
My internet connections downloadin speed is very .how to increases speed
Windows XP Users (NOT Vista users, see next step for XP/Vista users)
UPDATE: There has been a recent Automatic Update (MS08-001) released on January 8 2008 that addresses some network security concerns. The below has NOT been tested with the latest TCPIP.SYS (v5.0.2195.7147) file. Update:The patch has been tested with KB941644 (an automatic update) and works perfectly!
  1. Go to this site - http://www.lvllord.de/
  2. Click on Downloads.
  3. Right-click the link and click "Save Target As".
  4. Save it in your Desktop.
  5. Open the file and run the program located inside the archive, agreeing to the security warning.
  6. Some text should scroll by in a MS-DOS window, after it ends, type C.
  7. Enter 100 for the number of concurrent half-open connections and press Enter.
  8. Type Y and the file should be patched. Cancel any Windows XP warnings that should appear, it is part of Microsoft's way of ensuring its files are not tampered with (the utility tempers with them on purpose to change the limit).
Windows VISTA/XP Users
WARNING: The below is a relatively new patcher in the scene and has been reported working for many users. If it fails for some reason, please let us know in the Comments below! This patcher claims to work for both 32 and 64 bit Vista and XP versions.
  1. Go to this site - http://half-open.com/download_en.htm.
  2. Download the ZIP file in the link titled Download Half-open limit fix
  3. Extract all files to one folder in your desktop
  4. Open the folder and run the Half-open_limit_fix_2.3.exe file
  5. Click English
  6. Under 'New value', set it to 100 (if it is not already set)
    Set the new value to 100
  7. Click 'Add to tcpip.sys'
  8. Click OK.
  9. Click OK again.
  10. Restart your computer.
  11. If something is not working right and you want to undo the changes, run the software again and click "Restore original file".
**WINDOWS 7 USERS NO NEED FOR THE ABOVE**
Finally set the Port Forwarding for your application inside your router...
howto: follow the link http://portforward.com/
Mar 08, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
The modem & internet lights on router are flashing orange. All other lights are solid blue. The Verizon DSL modem indicates it is working properly. Have re-set once. What do I do now?
Its your network that's causing connection problem!
1. Try to connect to your network after half an hour!
2. If the server is still busy, don't surf during peak hours! (surf @ night)
3. Change your ISP! (last solution)
Jan 02, 2010 | Office Equipment & Supplies
The modem light wont stop flashing amber
Replace it , they dont last long and often chips go inside them,cheaper to have replaced than repaired.
Jan 13, 2018 | Belkin Computers & Internet
My pc cant find a conection from the modem
First of all check  if the lights are ok and connection is active.
Call your ISP and ask them if they activated your connection.
Be more specific if problem persist, what is modem model, brand, ISP...
Hope I helped you a little :)
Nov 24, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My internet stopped working when going through the router a week and a half ago. Do I need to update something? I works going directly through the cable modem.
you mean no internet connection? please check the modem coming from your ISP is the internet Ok...your lancard check also if its blinking.. if none from your lancard is blinkng there is no conenction between your modem and the CPU....or your lancard is defective.you have to replace it with a new one.you can call also your provider to check if you have ionternet connection no interruption usually it happnes when your prtovidfer done somthing to inprove there services.
Oct 10, 2009 | Trendware TEW-432BRP Wireless Router...
Belkin router problems with RCA modem
Do a powercycle. Make sure to completely turn off the modem, router, after 30 seconds, turn on the modem first then the router.
If that will still not work, perhaps there is a need to update the software of your router.
Aug 24, 2008 | Belkin (F5D7230-4) Router (587009)
80710092
Try changing the ISP from your Network Options menu. Change it to something random. And then try your ISP or 127.0.0.1 Hope this helped.
Jul 09, 2008 | Sony Playstation 3 (PS3) Console
ADSL Dropping on DSL-G604T
You can try something to narrow down where the problem is. Plug your pc directly into your modem and unplug your router altogether. This will not allow you to use you other computers on the internet. Don't worry you only have to do this for 4 or 5 hours. If the pc remains on net and you have no glitches then you might want to think about getting a new router. Since the router worked fine for 8 months, I wouldn't think the settings got changed. Routers aren't perfect pieces of equipment, I have had to purchase 3 in 4 years.
Jun 29, 2008 | D-Link DSL-G604T Wireless Router
Hi ive tried to update the firmware on my dlink router and it stopped half way through and now i cant connect to it
If you are running Windows Home or Pro...I suggest doing a system restore to the day prior to the upload.
Your router should be back up and working..
Always make sure that the "update" you are doing, is for your system. There are updates out there now that include Windows Vista....downloading these instead of your version, maybe change your settings and render your peripherals useless..
~~Jasta~~
Apr 04, 2008 | Computers & Internet
Dropping about half rx packets
proably that bad roghter not best best is linksys made by cisco ther new one n so fast 20 times of any others ok cheak online for yours see if u have a frimware or updates avb for that unit from ther site ok half duplx 10 mb sec still super fast then any network can offer u thx nick
Feb 06, 2008 | D-Link DGL-4100 Router (DGL4100)
D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
