Question about HP LaserJet 3055 All-In-One Printer
Error when i m installing the hp 3055 printer, its giving me a error like 'Access is denied' what can i do to solve this problem.?
    President:
  • 4,402 Answers
First I had to find out where the error message came from (scan in my case, see the description of my problem). Apparently Win XP, Me and 2000 have a security function that doesn't let you overwrite existing twain and/or twunk files.
So you have to install these files manually:
Search on the installation CD or in the unzipped downloaded full solution the folder setup\scan, there you'll find the file data1.cab.
Doubleclick it and extract the following files to a temporary folder:
F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892
F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892. F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892.
Rename these files to twunk_16.exe, twunk_32.exe, twain.dll and twain_32.dll respectively
Copy (and overwrite if necessary) them to the Windows directory (c:\winnt in my case)
Now you can re-install the complete HP software again, in my case it worked and I'm now able to fully use my CM1015 multi-function printer!
Posted on Dec 13, 2007
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
Help with HP Deskjet D1560 Printer!!
Solution 1
Right click on setup file and select run as administrator
Solution 2
  • open registry editor, start -> run -> type in: regedit
  • Open Hkey_local_machine folder
  • Open System folder
  • Open Currentcontrolset
  • Right click with mouse on enum
  • Select Permissions
  • make sure user: SYSTEM has FULL CONTROL permission
  • See picture:
Make sure system has Check On Allow Full control and read.
Check all users listed that there are no checks on deny.
You can also press ADD to add your own user, then click advanced, then click find now , select your user, click ok, click ok, give your
user full control and read permission.
Apply and ok. double check that there are no Deny permissions set.
let me know the results and do not rate solution untill we have solved the problem.
Thanks,
Ekse
May 05, 2009 | HP D1560 Deskjet Printer InkJet
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
HP LJ 3055 Toolbox Not Connected
Hi SaveWetland!
Without being able to see your machine, I'm going to make an educated guess at your problem. Many times, when a printer is used over a network, only the printer driver itself is actually installed on each user's machine. Utilities, such as the HP Toolbox, may not be installed. If your network administrator allows it, you could download and install the complete printer software package off the HP website, which I'm highly confident would solve your issue. If not, I'd advise you to contact your IT person and have him/her install the complete package for you.
Good luck and I hope this helps. Please let me know, and also provide a rating if you deem it appropriate.
Bob
Oct 15, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
Access Denied
Just see are you login as Administrator or try to install manually with driver which is digitally signed!
Jan 23, 2008 | Office Equipment & Supplies
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
221 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
