Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Smegg 90cm duel fuel dbl oven
Sorry to bother you with such a trivial thing ,i mislayed my instructions and cannot set the clock again !
  • 833 Answers
Go to www.smeguk.com and you should be able to get help
Posted on Dec 12, 2007
I have a indesit 90cm duel fuel cooker can some one tell me how to dimantle the oven door so i can clean in between the two pieces of glass
first you need to remove the door from the oven, Open the door fully and on the hinges you will see a little flap bit on each hinge, flip them over so they lock the hinges open.
Left the door up slightly and you will be able to remove the door.
Place the door on a soft surface handle side down and remove the screws around the edges, You will see how it is held together and be able to finish taking it apart.
When putting it back together make sure the insulating material and the rubber seals are located correctly.
Mar 06, 2012 | Indesit Kitchen Ranges
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
There is no display on the clock at all and cannot set it so the oven doesn't work either.
apart from a faulty clock. a thermal cutout may have tripped due to an overheat (either a long days cook or a faulty thermostat...) would be best to get a pro in to sort out as this is a duel fueled unit & entering the gas domain it's best safe this time of year... sorry
Dec 18, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
Aug 10, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
166 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Steve Allison
Steve Allison
Joseph Mueller
Joseph Mueller
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
