Question about Hoover HCA390FFK Bottom Freezer Refrigerator
Thermostat When I turn the thermostat down to the off position, you can still hear the compresssor running,and everything in the fridge is frozen solid. I am going to replace the thermostat.   Can you tell me how to do this please?
  • Janet Ann Green Dec 15, 2007
    Thanks anyway. Unfortunately, I know for a fact that this fridge freezer has only one thermostat controlling both fridge and freezer!
    Problem Solver:
  • 12 Answers
Without knowing the type of fridge you have, I don't know if this applies. Some old, and most new ones, have two thermostats. One for the freezer, and one for the fridge. The freezer one is the only one that can turn off compressor, the fridge one cannot.
I send this just in case it applies, and you did not know. Otherwise disregard it.
Posted on Dec 15, 2007
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
The fridge is frozen - the temperature guage says 6 degress celsius but everything in the fridge is frozen solid!!
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 30, 2009 | Refrigerators
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ge freezer works fine but the fridge wont
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezing in Fridge
Does the compressor run continually? Will it turn off when the thermostat is turned all the way down?. If it runs all the time it is possible the defrost timer is not working. It is located under the unit where the water tray is. Along one side or even at the front there will be a black plastic box with a shaft coming out that with a flat tip screw driver can be turned only one direction. Try turning it slowly to see if the compressor shuts off. Also mark the shafts position and see if it has changed after a few hours. It should. If not it is bad. If the unit doesn't shut off when the thermostat is lowered all the way, it could be the problem.... Start with the defrost timer first...
Feb 15, 2008 | Refrigerators
Hoover HCA390FFK Bottom Freezer Refrigerator Logo
213 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
tom wright
tom wright
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
