Question about Denon AVR-883 Receiver
Open Question DENON AVR-1803/883. CPU CXP74096-169Q short on 5,6v (pin 54-41,88). Where to get CXP740096-169Q for replacement. I live Russia the Kaliningrad area.
  • m900 Dec 12, 2007
    Whether it is possible to receive from you CPU CXP74096-169Q on DENON AVR-1803/883 ¹ 2093307205 and under what price?
  • m900 Dec 12, 2007
    Whether it is possible to receive from you CPU CXP740096-169Q on DENON AVR--1803/883 ¹ 2093307205 and under what price?
  • 1067 Answers
SOURCE: Denon AVR-1905 remote grenteeed fit match
Posted on Jan 26, 2008
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
Espagnol as well ...I think
Posted on Feb 16, 2009
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
Posted on Mar 02, 2009
  • 4 Answers
SOURCE: Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Posted on Mar 17, 2009
  • 6784 Answers
SOURCE: shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
Posted on May 21, 2009
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
I have a Denon AVR 1509 and when I turn the power on it flashed green but after about 2 seconds it cuts out and and then flashed red every 0.5 seconds.
Usually its the power output stage . You can visibly check it if theres a burned resistor on the output amplifier. On the base of the Power output transistor if the voltage is the same as the collector pin it will indicate a shorted power amplifier circuit.
May 20, 2010 | Denon AVR-1508 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I have a denon AVR-2000 that has gone into protect mode how do i get this off?
power output short....or spk or spk wire short check and .need service...
Jan 07, 2010 | Denon AVR-2800 Receiver
Denon AVR-683 won't stay on
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Jul 24, 2008 | Denon AVR-683 Receiver
Denon AVR 1603 goes to stand by mode
It has a blown channel, unless you are good at repairing them I suggest an authorized Denon service center. This Denon not only needs the shorted output transistors replaced, but a few resistors, a couple of driver transistors and a capacitor on the preamp board as well. alot of parts to be replaced. I have repaired about a hundred of these over the last few years and my shop charges about $200 for this repair, other shops should be about the same.
May 24, 2008 | Denon AVR-1603 Receiver
I'd look here first:
Dec 18, 2007 | Denon AVR-2307Ci Receiver
Denon AVR-883 Receiver Logo
67 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
