Question about OKI MICROLINE 520 Matrix Printer
Oki microline 590 elite
When i print a job sheet the next sheet doesn't line up so i can print again, i can only print 1 at a time. i have to tear,tear the sheet off, tear again and manually line the sheet back.
Printer does not print chinese characters
Posted on Jul 30, 2010
  • 40 Answers
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Posted on Dec 31, 2007
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
I have a OKI Microline 590 Matrix Printer at my store. When we used to hit Utility it would print decently. The ink would be on the lighter side but it was legible. Recently someone came in to change the...
Re-install the printer ribbon. It's probably slipping or dragging on the head mechanism, and the printer synchronization control is slowing everything down to compensate.
Mar 08, 2011 | OKI MICROLINE 590 Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Lighting hit building. the oki 590 has no power. Fuse is ok. What would I look at next. Bob
Oki printers are known for boards going bad even from static discharge from your hands. More than likely you have blown the main board. I have replaced way too many Oki main boards, if you like the printer, replace the board. Otherwise get a lexmark line printer.
Aug 04, 2009 | OKI MICROLINE 590 Matrix Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Setting up printer for reports & checks
Press SHIFT+MENU together to enter MENU mode
press GROUP until it prints EMULATION - make sure it doesn't shows UTILITY
Best Rgds
KM Hoo
Dec 28, 2008 | OKI MICROLINE 590 Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
I am trying to hook my printer up to my new computer and the disk I have is not working. i do not have a cd for microline 590 elite dot matrix drivers
The drivers should be on the company website, if these are not working for you the generic text driver in Windows will work for text only printing. If you do graphics or formatted invoices, etc. on the printer Epson and Okidata both make pretty generic print drivers that should work for a microline printer.
Jul 31, 2008 | OKI MICROLINE 591 Matrix Printer
Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Aug 31, 2007 | Samsung OKIDATA - OKI Microline 590...
OKI MICROLINE 520 Matrix Printer Logo
772 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
