Question about Intel D945GNT Motherboard
Mistankenly i connect config jumper on fan connecctor
Mistankenly I connect config jumper on fan connector Motherboard D945gnt Processor 3 Ghz and 1 gb ram.Not it run properly but after few menute its shutdown automaticaly when I restart next time It shows "previously computer shutdown due to processor overheating " and than start normaly and again shutdown.Please help me.
  • jigboring Dec 12, 2007
    yes I try that but it did not solve my problum.any other solution
  • jigboring Dec 13, 2007
    I also removed the cmos(for five minutes) on that time and start my computer but it did not solve my problem.
My syetem shutting down automatically and when I restart no response its happening system crash when I do the scanning it is happening . After few minutes waiting and then start a system its response and message showing message " cpu was previously sshutdown due to a thermal event, click enter to satart". Please help me to rectify regularly scanning by CA antivirus weekly ones online scanning for removing malware and spywares. windows xp 1 gb memory all latest version installed purchased just before 4 months onl;y.
Posted on Jun 14, 2008
  • 1,066 Answers
Perhaps the power supply is damaged
Posted on Mar 01, 2008
I did not recover bios but i update the bios but problum still present
Posted on Dec 24, 2007
Can i use flash drive of bios recovery instead of cd or floppy
Posted on Dec 18, 2007
  • 1,601 Answers
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Posted on Dec 12, 2007
  • Thomas Christopher
    Thomas Christopher Dec 13, 2007
    did you try clearing the bios?
    If you cannot enter the BIOS Setup, clear the CMOS:
    1. Turn off all peripheral devices connected to the computer.
    2. Disconnect the computer’s power cord from the AC power source (wall outlet or power adapter).
    3. Remove the computer cover.
    4. Locate the battery on the board (see figure below).
    5. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the “+” and “-” on the battery.
    6. Wait one hour then replace the battery.
    7. Replace the computer cover.
    8. Plug the computer and all devices back in.
    You may also need to perform a BIOS Recovery after clearing the CMOS.
    Here is how.
    Thomas Christopher Dec 14, 2007
    Follow directions again leaving the battery out longer (1 hour).
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
[Motherboard manual -
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
Diagram of xps 630i motherboard connections
xps 630i motherboard layout
1 - unused fan connector
2 - power button (POWER_BTN)
3- front LED
4 - front panel USB connector (FP_USB)
5 - floppy drive (DSKT)
6 - master I/O board USB connector (MIO_USB)
7 - front panel IEEE connector (FP_1394)
8 - reset button (RESET_BUTTON)
9 - RTC reset jumper (CLEAR_ CMOS)
10 - password jumper (CLEAR_PASSWORD)
11 - internal S/PDIF connector (internal SPDIF)
12 - front panel audio (FP_AUDIO)
13 - PCI card slot (SLOT5 and SLOT6)
14 - PCI-Express x16 card slot (SECONDARY GFX SLOT4)
15 - PCI-Express x8 card slot (SLOT3)
16 - PCI-Express x1 card slot (SLOT2)
NOTE: This slot is not available in the dual-graphics configuration
17 - PCI-Express x16 card slot (PRIMARY_GFX_SLOT1)
18 - power connector (12V_ATXP)
19 - processor (CPU)
20 - processor fan connector (FAN_CPU)
21 - black memory module connectors (DIMM2 and DIMM 3)
22 - white memory module connectors (DIMM0 and DIMM1)
23 - main power connector (POWER)
24 - IDE drive connector (IDE)
25 - North bridge fan connector
26 - SATA connectors (SATA0-3)
27 - battery socket (BATTERY)
Dec 06, 2011 | Computers & Internet
My motherboard is getting power from a 450w smps coz the board LED gets on when I switch on the ups. But pressing the power button on the cabinet does not switch on the system. Please help!!!!
From your diagnoses you may have a bad Power On switch, or a bad Power Supply.
An ATX power on switch is connected to the motherboard's Front Panel header.
From there the circuit is continued through the ATX main power cable, and into the Power Supply.
The Power On switch connects the Soft Power On wire, to Ground.
(The Soft Power On wire is abbreviated as PS_ON. The wire is Green)
If the Power On switch is bad the Power Supply will not turn on.
A bad Power Supply will have a weak voltage power rail, (Or more than one)
Enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on.
No Processor operating, no computer.
1) If all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use from 51 to 125 Watts. Depends on what Processor it is.
(Older Intel Pentium III's, and comparative AMD processors used less than 51 Watts)
You may have enough power to light that LED light, but not enough to spin fans, or turn the Processor on.
There is a simple test to see if the problem is the Power On switch, or the Power Supply.
Bypass the Power On switch.
A jumper wire is used to temporarily connect the Soft Power On wire to ANY Ground wire.
The connection is made at the Back of the ATX main power cable's connector, with the ATX main power cable plugged into the motherboard, and computer plugged into power.
1) The Asus M2N-MX (And SE version) motherboard uses a 24-pin ATX main power cable.
This is one example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
Looking at the photo to the far right, shows the 24-pin ATX main power cable plugged into the motherboard.
This is the position for the test.
(Computer also plugged into power)
The BACK of the connector is where the wires go into the connector.
The jumper wire is used on the Back side of the connector.
One end of the jumper wire goes down into the socket hole with the Green wire.
(Soft Power On wire)
The other end of the jumper wire goes down into ANY socket hole with a Black wire in it.
ALL Black wires are Ground wires.
The jumper wire goes down into the socket hole RIGHT NEXT TO the existing wire.
The jumper wire MUST go down into the socket hole far enough to touch a metal terminal.
At the end of every wire going down into the ATX main power cable's connector, is a metal terminal.
The metal terminal is pretty far down in the socket hole.
The preferred jumper wire used is a paper clip.
The paper clip's diameter is small enough, to go right next to the existing wire in the socket hole, and touch the metal terminal.
The paper clip is straightened out, then bent into a U-shape.
The 'legs' of the U-shape go down into the two socket holes.
The middle is wrapped with a few wraps of black plastic electrical tape.
The taped area is for your finger, and thumb to hold onto.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
There may be a small spark when you make the connection, advising you in advance.
The connection made is no longer than 2 seconds.
(The Power On switch is a Momentary Contact Switch)
Computer comes on, (Power Supply actually) you know you have a bad Power On switch.
Computer does Not come on, you know you have a bad Power Supply.
For additional questions please post in a Comment.
Jul 10, 2011 | ASUS M2N-MX Motherboard
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
My Mother is Intel D945GNT with Intel D Processor. Ipurchased it in 2006. From that time till 2007 it works properly. After that there is hang problem comming, and during hang also the display became hazi...
The onboard video chip is dying. Since it's a part of the chipset, it might be also dying. If you're lucky all you need to do is to add a separate video card, disable the onboard video and your problem will go away.
Jul 31, 2010 | Intel D945GNT Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Intel d945gnt
Yesterday night i resove the problem with the intel by many e-mail.
For all guys that have the same problem , the solution is:
1- put the jumper in position pin 2 and 3.
2- turn on the PC with jumper in the same position ( pin 2 and 3)
3- the bios start in "recovery mode"
4- deselect the memory "aggressive mode"
5- save bios setting, then power off the PC
6- set bios jumper in position 1 and 2
coolhandan thx for attention and please insert this solution in intel D945GNT archive for future customers that fall in same problem. Sorry for my bad English ;) THX at all
Nov 18, 2008 | Intel D945GNT Motherboard
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
CPU fan
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Feb 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel D945GNT Motherboard Logo
222 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
