There is a black sensor that detects when the door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
When the door closes, it strikes a switch which will "open" the circuit and terminate the light. Try opening the door, locate the light switch and press it in with your finger. Does the light turn off? No? More than likely, it is a faulty switch (constantly closed) which doesn't open and break the circuit (voltage constantly flows to lamp).
Should the light go out when you press the switch, you may have a door alignment issue and can adjust accordingly with specific screws (or retighten existing screws)
Possible that one of the door switch is faulty and so is open. You will need to check one by one , the switches, to confirm this as the open switch determines the light to be ON and makes you think that all the door swithces are faulty.
The cause of the problem is either a blown thermal fuse, a faulty belt switch (loose or worn out belt), a faulty door switch, or a faulty machine control board. Activate the "Diagnostic Test Mode" to determine which you should check first to avoid unnecessary disassembly of the machine.
Diagnostic Test Mode Activation Procedure
Unplug the machine for fifteen minutes.
Make sure the machine stays in standby mode when it is plugged back. That is, no indicator light is on.
Press the following button sequence within five seconds: More time>Less time>More time>Less time
All of the indicators on the console should light on and "88" is displayed on the Estimated Time Remaining display panel. It means no fault is detected and the belt switch is faulty or the belt is worn. Replace whichever is necessary to be replaced.
If E1 or E2 flashes on the display, the thermistor has failed and the thermal fuse is open. Replace both.
If E3 flashes on the display, there is a fault in the machine control board. Check the board for loose connections or replace it.
Open and close the door. There should be a "beep" everytime the door is closed and opened and "OE" is displayed whenever the door is opened. The door switch is faulty if no "beep" is heard or if "OE" is displayed even when the door is closed. Check the wiring harness connection or replace the door switch assembly.
Please inform me about the result of the test to give you the exact repair/replacement procedure.
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
Hello
ALARM CODES
Alarm
code Description of fault User
code Effect
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
