A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
make sure lamp cover (first plastic cover that was removed from tv cabinet to replace lamp) is fixed back properly because 3 times red light flashing indicates that lamp cover is not in its place. Thanks.
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely.
If the red light flashes 5 times this means that the lamp driver is defect.
If you need more help please advice
