Question about Clarion Car Audio & Video
Subs instalation how to parilel 2 subs off 1 mono block ? a diagram would be great thankyou.
  • 47 Answers
WHAT TYPE OF SUBS WHAT TYPE OF AMP
Posted on May 13, 2008
  • VADINIA VARGAS May 28, 2008
    2 OHMS OR 4OHMS SPEAKERS 1,2,4,8,OHMS STABLE AMP?
I have 2 2 ohm dvc alpine type r 12 inch subs. Each voice coil on both subs reads 2.5 on ohm meter. I need wireing diagram to hook up to a boss 2500 class a/b amp at 2 ohm
To have 2x 2 ohm subs wired up, they either need to be wired in series or in parallel. In series, they will total as a 4 ohm load to the amp (or 5 ohms if 2.5 each) and in parallel, they will be 1 ohm (may be closer 1.25 ohms I think).
If this is a mono block (single channel) amp, I can't see that you will be able to wire them for a 2 ohm loan. You may have to wire them in series to be a 4/5 ohm total as the amp probably won't be 1/1.25 ohm stable.
Apr 27, 2017 | Alpine Car Audio & Video
Tip
How to wire subwoofers correctly.
If you're ever unsure about how you need to wire your subwoofers to get the correct ohm load to your amplifier there are a few resources to help. Usually in the owners manual that comes with your subs and your amp they include a detailed ohm load calculator. First step is to determine what subwoofers you have. Common subs come in a dual 2 ohm or a dual 4 ohm version or a single 2 ohm or a single 4 ohm version. Next determine what ohm load your amplifier is rated at. Mono "subwoofer" amps usually are rated x amount of watts at either a 2 or a 1 ohm load. This means you need to purchase the correct subwoofer combination to match your amp. If youre purchasing 2 dual voice coil 4 ohm subs then to maximize an amp you should buy a mono amp stable at 1 ohm. and Dual 2 ohm subs would need a 2 ohm stable amp wired in series parallel. A great resource for a beginner is to go to www.the12volt.com and on the top of the page find the words "subwoofer wiring diagram" and click on it. This will bring you to a drop down menu where you choose the number of drivers "subs" or "speakers" you have and then you choose the impedence in the next drop down menu. Next you'll be provided with multiple wiring options. Good luck and never think you can't do it yourself. Once you learn it's very easy to retain.
on May 31, 2010 | Car Audio & Video
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
peace-out
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
How do you make two dvc subs run at one ohm and put them to a 2 ohm mono block
Make sure your amp is one ohm stable. If you wire the subs at one ohm and the amp is not a one ohm stable you run the risk of blowing the amp if not both the amp and the subs
Sep 22, 2008 | Xtant A3001 Car Audio Amplifier
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
Car Audio & Video Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
