Question about Candy CDC266 Dryer
Filter light on have cleaned filter/condencer
Filter light goes of when gets to cool cycle/ no heat
  • shropdive Dec 29, 2007
    have fixed problem it was thermostat on rear of machine.
    have new printed curcuit for sale cd266 £ 10.00 plus post
    tel 07973 526551 andy
    Problem Solver:
  • 8 Answers
First check the vent pipe for being bent or the flap outside for being stuck ?
Posted on Dec 15, 2007
Gas lg steam dryer DLGX7188RM cleaned filter , vent tubing, unplugged, still check filter light flashing , hit power goes straight to cool down .
the check filter light is just a reminder. it is not connected to a sensor. goes out when you start the next cycle so your issue is not connected to that.
May 30, 2016 | LG Dryers
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out or for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
Is there a heating over load cut out switch on the tumble dryer to be reset as it will not heat , I have cleaned filters and condencer
there is a thermostat (about the size of a quarter) located by the heating element that could cause this. It controls the heating element.
Oct 10, 2014 | Dryers
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
No heat, but dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Apr 27, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Same problem. Just bought it used, all vents are clean
If it shows cooling, it sounds like the sensor bars need to be cleaned off. They are two silver strips about 5 inches long just on the drum side of the lint filter. When dryer softener sheets are used, the bars get coated with a waxy substance, and then they do not detect the moisture in the clothes, so they think the clothes are dry, and proceed to the cool down cycle. You should be able to do a timed dry cycle just as it is, but will need to clean off the bars to get all the auto dry cycles to work. NOTE: If timed dry does not heat, post a comment for additional items to check.
Aug 15, 2009 | LG DLG2532 Gas Dryer
No heat!!!!!
have same problem /light goes of when in cool cycle.
i think its the printed circuit panel at top of dryer
have ordered one for £9.30 plus postage
hope it works
clean filter out and condenser element
Nov 24, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
111 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
