Question about Compaq FS7600 17" Flat Glass Monitor
Monitor resolution My monitor resolution will only set to 640x480 It has no other options in my properties menu to choose from. I would like for it to be the normal 1200x800 or so
    Brigadier General:
  • 6,966 Answers
It is possible that it is not a monitor problem but rather a video card issue. If in your desktop display properties you have only 1 selection (640 X 480) then you need to install the necessary drivers for your VGA/Video chipset.
Pls post back video/graphics details. If you have a built-in to the motherboard, post the brand/model of your PC. If it is an add-on video card, pls post brand/model. It would be of help if you can also post your operating system.
Good luck and kind regards.
Posted on Dec 12, 2007
Black screen in jump start
Go to the Properties of the shortcut, choose Compatibility tab, and place a check in the option to run the program in 640x480 resolution.
Feb 08, 2014 | Jump Start JumpStart 3D Virtual World...
I just installed cosmi casino on my dell laptop. The display is set for 1680x1050. But when I start up the casino games the display comes up 640x480. I go to the display section on my cmptr. and it...
Maybe the game settings is set to 640x480.Here follow the steps below if this will help you.
  1. Run the Game
  2. At the menu screen, go the the Option then check the video or display settings if it is set to 640x480.
  3. If it is Set to 640x480 change it to 1680x1050.
  4. If the display is already 1680x1050 then try the 2nd option below.
Another option.
  1. On your deskop, Right click the icon of Las Vegas Casino.
  2. Then on the menu, choose properties,
  3. On the Properties, go to the Compatibility Tab.
  4. On the Compatibility Tab, check the display settings if the " Run in 640x480 screen resolution " is activated, if Yes then just uncheck the box and then click apply and Ok.
  5. Run the game and you should be in 1680x1050 resolution now.
Goodluck, hope my solution will help. Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
Jul 10, 2011 | ValuSoft Las Vegas Casino Players...
I have problem in my lg lcd monitor when start computer windows loading then il say out of range 53.5Hz/85Hz. i don't know how to solve that problem.
Sounds like the resolution is set to high which is why that message would come up. When you turn on your computer, keep pressing the F8 button. It will bring you to a menu. Choose "Safe Mode" and press enter. When you get into windows go into the display settings in the control panel. Then go ahead and set the resolution to 640X480. After you do that go ahead and restart the computer and let it boot up normally. That message should go away and once you get back into windows you'll have icons that look bigger then normal. At that point change the resolution to 800X600, if it takes that then try 1024X768 if you want to.
If after you are in safe mode and change the resolution and that error message comes up then you'll need to download the video drivers for your computer and reinstall them.
May 28, 2011 | Computers & Internet
The Screen turns black when I attempt to start windows normally. It sounds like windows is starting, but nothing appears on the screen
It sounds like windows has been set to a screen resolution beyond the limits of the capabilities of the built in LCD. Luckily windows has a menu that allows you to change to a highly compatible low resolution mode. To select this mode, start tapping the [F8] key just after the HP/Compaq screen when the computer switches on. Hopefully if you pushed the button in time, you should be presented with a menu. Use the up and down arrows on the keyboard to select the option that says either "Enable VGA Mode" or "Enable Low Resolution Video (640x480)".
Windows should now load, but everything will look extra large. To fix this, go into your display properties (right click on desktop and select either "properties" or "screen resolution"), and choose the recommended screen resolution.
Dec 24, 2010 | Compaq Presario CQ60-220US PC Laptop
Problem showing "out of range
You need to change the display resolution of the computer. for the purpose you change the video adapter settings as follows:
Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
Right-click the desktop, click Properties, and then click Settings.
then you change the resolution to 1024x768
and restart computer in normal mode
hope it will work, feel free for further assistance
do rate the solution if got help
Dec 03, 2010 | Compaq FP 7317 17" LCD Monitor
I changed resolution from 640x480 to 1024x768 and all i get now is a blank screen. cannot get back in to change resolution back to 640x480
reboot the computer in "safe mode with networking" by rebooting the machine and during the manufactures name screen, tap the F8 key and you will see the muli-boot menu come up. Safe mode usually loads a resolution the video card and monitor agree on. You may have corrupt video drivers that give the black screen. While in safe mode, go online to windows update and let it scan your system, choose custom installation and look for the optional updates, these will be the hardware drivers you need to update your system. Check them all if you like and let windows install them automatically. Once done reboot normally and see if that clears the problem.
Sep 20, 2009 | Computers & Internet
External monitor looks like the computer is in the safe mode
If XP:
Start->Control Panel->Display->Settings tab->Screen resolution->move marker to "more".
If Vista:
Start->Personalize->Display Settings->Resolution->move marker to "high".
Mar 12, 2009 | HP Pavilion dv4000 Notebook
E-machine W6409
The PC has been set to use an invalid display resolution,
to rectify this boot PC into safe mode, right click on the desktop (not on an icon) select properties
select the tab for settings, and choose the display resolution 640x480,
then reboot pc into normal mode, then using the same process above , select a more appropriate resolution for your display (remembering to also turn up the colour setting to at least 32 bit)
Oct 03, 2008 | E-Machines eMachines Desktop PC
Resolution message
Right click on your desktop and choose properties. Click on the settings for your problem monitor and you should find the option to change the screen resolution.
Feb 28, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Compaq FS7600 17" Flat Glass Monitor Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
