Question about HP Photosmart R725 Digital Camera
Cannot reset camera
I am getting error message 000000184489957000 and camera asking to reset. I have tried to reset, following the reset instructions in book, but camera error does not go away, and camera does not stay on or work.
please help
  • 9 more comments
  • shariev Dec 17, 2007
    I have the EXACT same problem and no clue how to fix it
  • Anonymous Dec 22, 2007
    0000018-4489-957-000 error prevnts the cmaera from powering on. The camera powers on, displays the error, then shuts off. How do we fix?
  • Anonymous Dec 30, 2007
    i heve problem mit hp r725
  • kurai Feb 16, 2008
    I've tried resetting, playing with pushing buttons, letting the camera sit, and removing the battery and memory card, or even just the memory card. Nothing's worked, and I was just using the camera just fine 5 minutes before this started happening!
  • smlstf Aug 24, 2008
    When i try to turn the camera on is shows a red screen reading
    Camer has experienced and error.
    00000018-4489-957-000
    Please reset your camera
    The camera only stays on for about a second and then shuts off again. The shutter that covers the lense also doesnt close.
  • Jennifer Bushen Sep 30, 2008
    Thanks everyone! A little tap, tap to the corner and we are all set. HP wanted to change me $30 to talk to me on the phone. So thank you for saving me $30
  • Anonymous Oct 03, 2008
    i have the same problem only my error message says 5555aaaa-61ee-14b-031 i need help :(
  • Anonymous Oct 07, 2008
    I had the same problem and all I did was tapped it on the palm of my hand and it turned on like nothing. Had to reset the date and time. =)
  • Anonymous Dec 21, 2008
    ai have thi problem 000000184489957000
  • sfabtx Apr 15, 2009
    Unbelievable. I had the same problem and a little tap on the palm solved it. Thanks!!!
  • Anonymous May 05, 2009
    ha! I've had the same problem!! ALmost bought a new camera--- gave it the ol' tap and it fixed it immediately!! wow!
I was having the exact same problem. The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
Posted on Apr 16, 2008
Instead of beating up your camera try this. If the lens cover is open when the camera is off then look at the front of the camera, turn the camera on and the lens cover should close. Quickly hold down the lens cover with a finger to keep it closes. Very light pressure is all it takes. The red error screen will come back up, and the camera will shutdown again. now try to reset it and it should work this time. Must be something with the lens cover getting left in the open position that is causing the error in the first place and preventing the reset from completing. Worked for me (HP Photosmark R727), hopefully it will work for you too.
Posted on Aug 28, 2008
Had the same problem and I took Tkay86's advice and it worked. I did the reset thing quit a few times but it didn't work, so I tapped the corner where the lens is and it started working again! But another thing, like the other person said...don't let the battery die...keep it charged.
Posted on Aug 22, 2008
  • 4 Answers
I just had the exact same problem as noted above. Whenever I powered on the camera, the lens cover briefly closed, the red error screen popped up just as the cover opened again then the camera shut itself off almost before I could read the error screen (leaving the lens exposed of course). I must have power cycled the darn thing a dozen times just to grab the error code so I could google for it.
I tried holding the lens cover closed with my finger as I powered it on, but I never thought to give it a good whack.
My trick never worked, but the good whack to the corner fixed it right away. Thanks!
Posted on Jul 01, 2008
YOU PEOPLE ARE FRICKIN' GENIUSES!!! I had the"red screen of death" as well...tried resetting...nothing. Resigned myself to buyin' another $200 digital camera in 6 months (1st one was inadvertantly "slapped" out of my hand by a wife who said I was being an idiot at the time) Anyways, it was just like CPR, one tap on the palm...nothing! CLEAR! Second tap on the palm...nothing!! CMON, BREATH ****! Third tap...WE HAVE A LIVE ONE!!! Thanks to all! :)
Posted on Jun 25, 2009
I had the same error. I tried to reset it but it wouldn't work. Finally, after trying for about an hour, it came on with the date and time screen. I think it worked when I reset it, waited for about 10 minutes, and then hit the flash button when I powered on. I can't remember exactly. Keep trying, it will work.
FYI, I was getting a red screen and the error 0000018-4489-957-000, and then it would shut down.
Posted on Dec 24, 2007
Same error and same solution.....thanks everyone :)
Posted on Jan 05, 2010
Totally worked! When I read it I was like " This is so not going to work!" I litterally thought I had to get a new battery! I was online looking to order one and then I spotted this! I havent used my camera in a year! Exactly! I just gave my camera a little pat on the back and i almost screamed! Now I will be taking a lot of pictures the next few weeks! :) you were a great help sfavtx!
Posted on Jul 31, 2009
I coulnt believe it when it started working but yes...has the same problem as most and thought it had something to do with the lens also as i noticed it wasnt closing when the power was off. So like the recommend suggestion i held the camera in my right had and hit it in my right palm 2-3 times as had as i could. turned the power on and "BINK" it started working again. Awesome! FYI: prior to this i did do the reset button and nothing changes,even held the lens lid down when powered up but no change. I think it may have something to do with the battery getting low or going dead and the lens becoming stuck and not closing making it go into reset/error mode. Who knows iam not expert but who would of thought at HP that a tap would fix the problem. HA!! Thanks to all for your help who posted.... :)
Posted on Oct 08, 2009
I actually went to buy a new battery and the guy at the store tested my battery and said it was fine. Gad I found this webpage, I was not sure it would work for me either, so I went and grab the camera, tapped it in my hand, turned it on, presto, went to the reset date screen and it is taking pictures again. Yay!
Posted on Dec 13, 2009
I had the same problem - red screen and error. Tap the corner where the open lens gently on a table and it will flip close then the camera should work fine.
Seems like most technology, a little thump and its fixed!
Posted on Jun 18, 2008
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
Olympus camedia c-50 card error when I put in a new card. It asks me to format then gives me the message. HELP!!
1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2. Insert the card, go into the menu and find "format"...follow the on-screen instructions.
Feb 11, 2010 | Olympus Camedia C-50 Zoom Digital Camera
Only stores to internal memory not memory card
1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, format the internal memory.
3.Don't wait for a message...format the card in the camera (never in the computer).
Dec 22, 2009 | Nikon Coolpix S51c Digital Camera
Olympus Stylus, keep getting error message to format card. Formatted card and had to erase pictures in the process. Took more pictures and got error message again. Plugged camera into PC and there are no...
Hmm....
Seems like your Memory Card already damaged and corrupted.If you still want to use it, try formatting it using your Computer, again and again.
If the problem still persist, there's no other way, you have to buy the new ones.
Dec 08, 2009 | Video Cameras
Hi Team hve a problem with Olympus Camedia C-450 Zoom Digital Camera - put in new memory card (original) and since cant get camera to work - I think the said camera is almost new - but I get error message...
You need to format a card in the camera to erase and optimize it for the camera. Go into the menu and scroll to "format" and follow the on-screen instructions.
Nov 14, 2009 | Olympus Camedia C-450 Zoom Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Error message on D70 freezing camera operations
I got this info from Nikon for D70...
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
  1. Remove all accessories from the camera.
  2. Install a freshly charged battery into the camera.
  3. If your Nikon camera offers resets such as the two-button reset or a hardware reset please follow those instructions provided in the product manual.
If these steps do not resolve the Err message we recommend having a Nikon Authorized Repair Technician evaluate the Nikon camera.
Hope this be useful for you to resolve problem.
Oct 07, 2008 | Nikon D70s Digital Camera
Sony Cybershot DSC-P200 Get error message whilst taking photo "Formatting Error" then image doesn't get saved on the memory card. This doesn't happen with every photo. I have replaced memory...
have you tried formating the card and camera
to format the card insert itinto card reader and go to my computer right click on the drive then select format and follow the instructions this should solve the problem
also try reseting the unit at the same time by following the onscreen instructions in the set up mode
Sep 11, 2008 | Cameras
HP Photosmart R725 Digital Camera Logo
1,175 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
