Question about Lexmark P6350 All-In-One InkJet Printer
Memory Card I inserted a memory card in the top slot. It disappeared into the slot, but is not being read`according to the laptop connected by USB to the printer. The memory card is a reduced-size multi-media card (RSMMC) from a Nokia 6630 mobile phone/camera. Please advise how I can (a) extract the card (b) proceed with transferring images from the card to the laptop.
  • 71 Answers
Unplug and tilt the printer so that it's facing down. Shake gently. If you get it out, you'll need to get a sd/mmc adapter. It usually comes with the card. It will make the card the same size as the SD card.
Posted on Jan 27, 2008
How to scan memory card?
Try connecting your phone to the computer via usb cable if your phone is capable of that and click your phone icon once it appear on the computer and left click on your phone and look for scan on the menu. Then your phone will be scanned. The other way is by taking off your memory card out in your phone and inserting it to a laptop and scanning it manually. Usually a micro sd are the memory cards thats being used on phones so you should have an adaptor for you to be able to insert it into your laptops SD card slot.Hope this helped you in anyway..have a nice day.!!!!
Mar 26, 2012 | Cell Phones
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
My memory stick pro duo is not read when I stick it into my memory card slot on my laptop. I do not have the USB cable to hook it in otherwise, is there a way to upload my pictures?
you can buy a All in one USB Card reader/Writer and then insert the memory stick pro duo card in it and plug in the USB Card reader/ writer
to the USB port on your laptop and you should find the same listed under removable devices under my computer. good luck
Sep 13, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Dont no how to get my photos from card reader too my laptop
An USB memeory card reader should have several slots to insert the various memory cards.
You insert the memory card into the correct slot on the card reader and then connect the CARD reader with the USB cable into the USB port on your computer.
The computer will see this as an external storage device, you can then copy the photos off the memory card into your computer.
Jun 30, 2011 | Computers & Internet
Hp Photosmart 8150 can't read sdhc memory card
Unless the SD slot is specifically designated that it can read the new SDHC (Secure Digital High Capacity) memory card it will not read even though it plugs intop the standard SD slot.. I checked and this printer can't read the SDHC card only the standard SD card. You can buy a SDHC USB reader on ebay for a few dollars.
Nov 24, 2010 | HP Photosmart 8150 InkJet Printer
Compaq 6910p Notebook does not recognize a SD-MMC memory card when inserted into the slot. The memory card is fine, as I can access it using a USB card reader, but it is not recogized in the Notebook's...
If the memory card is recognized and readable in a USB card reader, the memory card is fine. If the 6910 does not recognize the memory card, either the card is not properly seated in the 6910 card reader slot, the card slot is not connected to the main board of the 6910 or you need a DIFFERENT device driver for the 6910.
Nov 25, 2009 | Compaq Hewlett Packard 6910p Notebook
How do I download my camera's memory card onto my acer extensa
The "odd shaped port" you are referring to is most likely:
The Express Card slot (replacing the slot known as “PC-Card” replacing the slot formerly known as “PCMCIA”) are the biggest standard slot on a laptop designed to handle stuff like wireless cellular modems with antenna and micro hard drives. Most people won’t ever use this slot, but it’s a lot faster than it’s old relatives now that it connects directly to PCI-Express. From:
Do NOT put your memory card from your computer into that slot. Since you have indicated that the USB cable connector option will not work, you will have to go out and buy a memory card reader that is compatible with you memory card. They are relatively inexpensive and easy to find at most electronics stores. Plug in the card reader (USB) and seat in your memory card and the OS of your laptop should detect the card and allow you to download the pictures.
Hope this helps!
Apr 05, 2009 | Acer Extensa 5420-5687 Notebook
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
I have a simple question. How do I insert my scandisk memory stick pro duo card into my laptop to read? MY laptop has open slot 5 in 1 media card reader. I can insert all my other card and able to read....
You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
Dec 03, 2008 | SanDisk Memory Media
Lexmark P6350 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
