Question about Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television
Big vertical tinted stripe on screen
A very annoying problem has cropped up with my otherwise wonderful TV: major tinted vertical stripes across my screen. Note that the screen should be black here:
The middle stripe has a greenish hue, and the blue is stronger to the left of the stripe. It is most obvious when displaying darker colors, and seems to wash out with more saturated images. It is present with all input modes but doesn't appear to be "burned in". The problem developed suddenly - I only noticed it today and it's very obvious. Is this salvageable?
  • MikeBrady May 21, 2008
    The problem eventually resolved itself. Interestingly enough, the bands shifted slowly to the left until they worked themselves off the screen and didn't come back. I believe it was the blue tube that was going wonky. There was nothing on the lens, and nothing wrong with the projection mirror. I suspect it was something with the video circuit itself (dust maybe?), but for now I'm crossing my fingers and hoping it doesn't come back. Thanks for helping!
    Habit-Forming:
  • 15 Answers
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Posted on May 21, 2008
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
32 seiki tv vertical lines on screen and skip some ajustments like tint
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 23, 2015 | Seiki 32" LED TV - SE321FB
52" Mitsubishi projection TV has stripes
Depends on exact model number; if a WD-52525 or something very similar pitch it---they are falling apart and have all kinds of troubles.
Google the full model number with "problems" to see what issues the set has like a hundred bad surface mounted caps etc.
Apr 23, 2012 | Televison & Video
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV Picture problems
replace all caps in vertical area, if problem stays, try replacing pumpup diode and vertical. if still same problem check drives goin to the vert, and vcc goin to it.
Apr 09, 2008 | Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Blank screen
REPLACE ELECTRON GUN WHICH IS AT THE END OF THE CATHODE TUBE
Feb 21, 2008 | Panasonic CT-2784VY 27" TV
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sharp 28JW73H Green tint with lines across screen
Note: unmatched Make / model info........please clarify...T.
Nov 16, 2007 | Panasonic PT-52LCX66 Projection Television
Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television Logo
283 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
