Motherboards
Problem for Motherboards
Generic problem for all Motherboards
My HP photosmart 2710 will
By mcbbutton on Sep 16, 2009
My HP photosmart 2710 will not turn on. There is 31 volts going into it??
Comments:
Sep 16, 2009
- I said there is 31 volts going into it. The power suppy is OK. No lights not anything.
Sep 16, 2009
- My HP photosmart 2710 printer will not turn on. There is no lites on it and the power suppy is working 31 volts going in ???
How do you take it apart??
Sep 16, 2009
- The printer is about 3 or 4 years old. I said there is 31 volts going in. We had a guy into the house working on the electric wires on the GFI ??
Sep 16, 2009
- My HP photosmart 2710 all in one printer will not turn on. There is 31 volts going in.
Sep 16, 2009
- I have HP 2710 photosmart all in printer that is 3 or 4 years old and it will not turn. It has a 31 volts of power going into it. We had a electrian working on the gfi in bathroom in our house. There are no lites on the printer that are on.
Sep 16, 2009
- The 31 volts is correct??
Solution #1
posted on Sep 16, 2009
Somewhat Helpful)
clay58
Rank: Guru
Rating: 88%, 297 votes
Does it use a power module or is it wired directly from the outlet? It has 31 volts at the end of the power module which is exactly what it should have, so you know the power module is good. Try this. Quickly press and release the power button and then quickly repeat this one more time. If that does not solve the problem, Disconnect the power module, wait 30 seconds, and reconnect not using a surge protector or power strip. If none of this works, disconnect the USB cable and try another USB cable. Power the unit up and then connect the USB cable. If none of this works you would probably just need to buy another printer as the cost of repairs will be more than a new printer.
Comments:
Sep 16, 2009
- They stated the power supply is good and it is putting out 31 volts which is exactly what is supposed to be putting out. Did you try my suggestions? If you did and it is still not working then unless you can open it up and find the problem or the problem is at the connection for the power supply I am at a loss. It is obvious it is not getting power but the question is why. Some H.P. printers have a problem with the sleep function that I why I suggest your power it off and then quickly back on. I would open it up and following the wiring from the power connection on the back to the power button on the top. Good luck.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
niceguy_202
Rank: Guru
Rating: 86%, 194 votes
is it a new device? if you have used it well before, then try to plug it in power outlets where other devices can plug and work. make sure that the ends of conencting wires are in good contact, there may be loose connection
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
redhaze89
Rank: Guru
Rating: 85%, 203 votes
Option 1
If you have a blinking light try changing cart.
Option 2
If the unit is blackout change the power supply. Here are the specs
Power specifications
* Power consumption: 75 W maximum
* Input voltage: AC 100 to 240 volts - 2 A 50-60Hz, grounded
* Output voltage: DC 31 volts === 2420 mA
Was this helpful?
Yes
No
Solution #4
Not Helpful)
MNfisherman
Rank: Wiz
Rating: 85%, 2702 votes
that is a little high for voltage. Is this the power coming out of supply and going to motherboard? It should be about 12 volts.
Comments:
Sep 17, 2009
- I recommend having your power supply changed. You should only have 12-13.5 volts. If you are getting high voltage in the 30's, then there is a bad capacitor in the power supply.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
Problems with the P35 Platinum board. Gets stuck at the full screen logo display feature, cant go to... (More)
Answer
my CD driver was gone, and i can't install the driver of the motherboard matsonic ms158d, and i need... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motherboards:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
