Kenmore 24 in. 15079 Built-in Dishwasher
Problem for Kenmore 24 in. 15079 Built-in Dishwasher
Dish washer gets water but does not clean the dish
By pactract on Sep 16, 2009
dish washer gets water but does not clean the dish
Solution #1
posted on Sep 16, 2009
Not Rated)
localwonder
Rank: Guru  Kenmore Expert
Rating: 92%, 2978 votes
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15079 Built-in
Questions and Unsolved Problems for Kenmore 24 in. 15079 Built-in
Do you recommend Kenmore 24 in. 15079 Built-in Dishwasher?
Answer
Answer
Mod # 15835791 Kenmore dishwasher won't drain just makes a bumping noise
Answer
The detergent door is not opening during the wash cycle
Answer
top rack not cleaning --3 yrs old. I've taken the 3 screws out on the bottom--How do I get to the... (More)
Answer
I put something too big on top shelf and knocked off the disk on the upper arm the little washers... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
in , KY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
