Question about Bosch Washing Machines
Hi have a bosch front loader logixx8 will not go on the big spin just goes around slow can you help thanks
    Master:
  • 590 Answers
It seems to me that the water pump is not emptying fast enough that seems that there might be something stuck in the pump clogging the outlet,first of all turn the machine off blow down the outlet pipe,if you cannot blow into it then remove the back cover and remove the pump housing to remove the blockage,resemble and there should be an improvement in the spin problem
Posted on Sep 27, 2019
SOURCE:
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
  • 1075 Answers
SOURCE: banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: my bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Posted on Jun 16, 2009
heatman101
  • 43501 Answers
SOURCE: When spinning, my Bosch Front Loader W/Machine's
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 20, 2010
  • 6277 Answers
SOURCE: my washing machine model samsung
Hi from retired Englishman in SW France- Frid morning 11:52.
It does literally sound as if the belt is slipping! This can happen with time. I would advise purchasing a replacement belt to be fitted by a confident/competent person- as you might well be!
REMOVE POWER.
REMOVE THE BACK.
The motor and belt should be easily visible- on most front loaders they 'stare you in the face'.
The motor's support bolts will require slackening, the old belt will probably come off very easily. The new belt is likely to be quite awkward/difficult to put on as it is a tight fit. Once on the belt requires to be re-tensioned by pulling the motor FIRMLY so that the belt is quite tight- if it is not already, that is.
ON NO ACCOUNT SHOULD A LEVER OF ANY SORT BE USED. THE ACTION COULD DAMAGE THE BELT, MOTOR AND BEARINGS.
I believe this should cure your problem.
Good luck,
John C
Posted on Feb 11, 2011
F18 is flashing on a Bosch front loader washing machine ( Logixx8 Sensitive)?
If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Sep 10, 2017 | Washing Machines
I would like to download a user manual for Bosch Logixx8 sensitive front loader washing machine. Thank you Mrs Jae Watson
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Bosch Logixx WFT 2806 Front Load...
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
My bosch wfk2401 front loader is stuck on spin
Hi
Mark
Mar 04, 2009 | Bosch WFK 2401
Banging noise on spin cycle
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Whirlpool front loader error code f-h ? front loader will not spin
hi thanks for your question. i would check the pump remove the front panel 2 screws on the front panel at bottom remove you will see a big plastic nut in middle un screw but you will get water put a bucket under this nut pull out and clean . this will solve your problem thanks the appliance doc
Sep 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
