Question about Canon PIXMA iP4200 InkJet Photo Printer
Inaccurate error message
I get this erroneous message-more than one ink tank of the following color is installed cyan Canon Pixma iP4200 When I go to print I get the message 'more than one ink tank of the following colour is installed.  Black (5).  Use only one ink tank per colour at a time.'  I have to click the cancel printing button. I turn the printer off.  Turn on again - then open the lid to see the Black (5) ink is flashing - so I remove it and then put it back then close and go to print and it works OK. WHY?
  • maggie_p Dec 17, 2007
    I tried the suggestion I got on another forum to clean the chip on the ink tank with metho. It did work for a while then had the same problem again so even though it was a full tank of ink I put in a new one and haven't had the same problem (touch wood) since. I now want to get a replacement ink so will contact the supplier to see how, I have only used Canon ink since I purchased the Canon printer so Canon should replace it. We'll see.
  • Anonymous Feb 15, 2008
    What does it man to " to clean the chip on the ink tank with metho." What's "metho?"
    This is such a frustrating problem!! It's hapenned a lot!
I see the (now old) 4200 available for $50..... get a whole new printer for the price of a set of cartridges.... Adorama Camera at Amazon or their own site.
Posted on Dec 20, 2007
It is the technology. Canon printers are made to burn big holes in the customer's pockets. 4200 gives near lab standard prints however, the user's are made to pay for this luxury. I have been using canon printers for the last 3 yrs(4200 for a year). The main objective of the manufacturer is to compel you to buy those cartridges which are shamelessly priced for more than 10 times there worth. Again I am almost sure that every single 4200 user has encountered problems with cartridges(Genuine canon) the cartridges are so made that the tiny circuit board on it will refuse for no apparent reason to respond. the only remedy would be to throw the cart.away and get a new one. Cleaning/deep cleaning/head alignment/nozzle check etc are all aimed at sucking the cartridges empty.Don't get discouraged by those scary warnings about refilling or compatible inks. For smarter people canon allows some tricks (override error messages ...) If you are a professional photo printer like me use your 4200 as if it is an offroad 4WD drive for 3 to 4 months and throw away.
Posted on Dec 17, 2007
Mine does it with the cyan and it worked for awhile...if I take a cartridge from another ip42000 cyan, it works. Any ideas?
Posted on Dec 16, 2007
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma IP4200- not printing color
If it's a generic ink, try another one, if it's a Canon ink, make sure the tape on top is removed, it covers an air vent, if that doesn't help, you need a new printhead, QY6-0059-000 around $40.00
Jul 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
THE ORANGELIGHT ON FRONT OF CANON 1P4200 PRINTER FLASHES SEVEN
From manual:
Seven Flashes: The ink tank is not installed in the appropriate position
Possible causes are as follows:
Some ink tanks are not installed in place.
More than one ink tanks of the same color are installed.
Jun 09, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Ink tank error message Canon iP3500
Sorry this isn't a solution but I'm having the same problem. Even if I exchange the colors, it's always the cyan no matter what slot it's in!?!?! Not the slot.
Can I turn that color OFF???
May 29, 2009 | Canon PIXMA iP3500 Printer
Replaced two ink tanks in my pixma but the lights will not flash
You cant realy do anything, i had the same problem whit my IP5000.
I tryed everything but nothing helped, after speaking whit canon here in sweden they told me to let it be, after next tank instalation it will disappear and you printer will be as usal again. Canon told that the problem is on the chip on the tank. When the printer tell you that the tank is empty or not right just press the blinking yellow button on the printer and hold it for at least 5 seconds.
Good luck
Dec 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Canon Pixma ip4200 printer, error 1414
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Mike
If you could take a moment and rate this response, I would appreciate it.
Jun 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Fill out the form.
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
212 people viewed this question
old marine
old marine
