Question about LG 42PX5D 42 in. Plasma HDTV
Blue-ish colour develops after an hour LG 42PX5D
Blue-ish colour somtimes green top left hand corner of the screen after it has been on for an hour or so seems to depend on colour being projected. Also menu ghost on screen
  • Anonymous Dec 12, 2007
    hi i have a 42 pc1d lg plasma and seem to get image
    burn and green and yellow ghosting on bottom left area
    is this normal and can be adjusted or is the set faulty
  • kwkhong Dec 22, 2007
    I had this problem on my 42PC3RV. My top right hand corner had this pinkish contrast like burn in that white wash doesn't help.
    I had the panel replaced and it was fine for a few weeks and it returned again.
    President:
  • 1,284 Answers
There are voltages in the power supply that need to be very closely matched to the sticker that is on the back of the plasma display panel. If some of the voltages especially the VSCAN goes too high or too low then abnormalities such as discolorzation can happen. Changing the direction only affects direct view CRT's only. Plasmas are only affected by elevation and thats usually when you live 5000 feet or more above sea level. I would have a technician check the voltages once the panel has warmed up for 20 min or so and see if they are correct. Good luck.
Posted on Dec 12, 2007
YOU CAN CHANGE THE DIRECTION AND SEE THE WETHER THIS PROBLEM IS ARISING .
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
COLOUR ON MY TV IS MESSED UP.
palsonic tv is green and blue
Jan 11, 2009 | Televison & Video
Colour splashes on screen.
the lcd panels in the optics block are going bad, getting dirty etc., the block needs replacing and will cost upwards of $750.00 total.
google sony optics for your model for warranty extension possibilities.
Jan 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
I have a hitachi ultravision tv m#53sbx10b s#v1g000279 and everything works but there is a blue and somtimes yellow swoosh thing in the top left corner. it like fades throughout the colors? i was hoping...
Your Green CRTs coolant may be congealed giving the green tube a yellowish look it should be a vibrant green. Try changing the coolant in the CRT
May 06, 2008 | Televison & Video
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
LG 42PX5D 42 in. Plasma HDTV Logo
122 people viewed this question
