Question about Brother IntelliFAX 4100 Laser Fax
Very light fax pages coming through
Intellifax 4100 about 3 years old, pages are coming in very light. I tried a brand new drum. No difference. We have used recycled drums and toner before with mixed results. Could this be the problem? Is the machine just old?
    New Friend:
  • 116 Answers
May be laser unit problem
Posted on Sep 17, 2009
SOURCE:
Gray copies
Most likely you do not reset the drum. In this case, a new drum unit serves as the currents in the old, respectively, due to lack of charge is a problem with a gray background. Information on how to reset the imaging drum is open and is the official website of the manufacturer.
Jul 27, 2010 | Brother IntelliFAX 4100 Laser Fax
Toner on paper edges
The cleaning blade inside of the drum unit is worn out. Replace the Drum Unit
May 19, 2010 | Brother IntelliFAX 4100 Laser Fax
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
Apr 09, 2010 | Brother IntelliFAX 4100 Laser Fax
MY BROTHER INTELLIFAX 4100 PRINTS LINES ON MY PRINTED PAGES.
Try moving the blue slider on the cartridge back and forth 10 times to clean the charge wire. If this doesn't work, you most likely have a bad drum.
Jan 19, 2010 | Brother IntelliFAX 4100 Laser Fax
Have a brothers intellifax copier - fax about 5
clean laser... if still there change drum.. if still there clean ccd... if still there... contact brothers support and they will walk you through it or send you to a service center for it to be repaired
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Black pages
Try to copy a document. If the copy comes out black then the the scanner is dirty. Clean the scanner glass (products on the market that clean by sending through the scanner) and try to copy again. If after cleaning the scanner, the copy is still black you have a scanner issue and the laser/scanner unit will need replacement. Best of luck and please post back with any questions or just to rate the solution.
Greg
Aug 10, 2009 | Brother IntelliFAX 4100 Laser Fax
Change drum soon
Instructions are in the box that the new drum comes in.
Jan 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxes received are so light, the page looks blank
don't forget to try other fax-paper... your's might have already expired.... if this doesn't work... the printer's heater might need changing.
goodluck... hope this helps.
Feb 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
Aug 08, 2006 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
129 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
