Question about Dell Microsoft Windows XP Home Edition
Monitor when we got ot turn on our puter we have a white line that runs thru the middle. won;t turn on or off. Have to unplug the monitor from the back then plug back in to get the puter to work.
    Brigadier General:
  • 6,966 Answers
It would seem that you do not have a computer problem but rather a monitor problem. If you monitor displays a single line from left to right, then chances are that the vertical IC is defective and would require replacement. In some instances, the IC may not be defective but would require reheating the solder joints. In some other instances it may be the vertical capacitor and/or some other associated components.
Since this would require opening the monitor, familiarity with electronic components & circuitry, use of a DVM and/or a soldering iron, then perhaps your best bet would be to seek the services of a qualified monitor technician.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Posted on Dec 12, 2007
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Hi..pls..help..my jvc television, im watching then turn off have a power but sadly it has a line at the middle of monitor and turn off.
You have a vertical amplifier failure or dry solder on the vertical IC. When cold if the TV works for some time and then you are getting a thin white line in the middle of the screen after some time -- its a dry solder problem. The vertical IC runs very hot in the TV and develops dry solder after a few years.Will run when cold and switch off when hot.
Are you well versed with electronics to do the repair yourself ?. If so, revert back and I will guide you if you mention the TV model #.
Apr 11, 2011 | JVC Televison & Video
We won a new sony tv, after setting it up, i was adjusting the color,when tv wentBLACK with white lines running thru it,unable to get picture again.thanks chuck
Tries unplug,replug the tv back like an hour.Now,the tv is resetting itself back to factory setting.The tv should work again.If not,the tv Tuner signal board have problems.Tv is less than a year old wright?Call Sony Corp. for a warrenty repair.
Oct 17, 2010 | Sony Televison & Video
White line about an inch wide down the middle of the screen. Otherwise picture is clear and sound is good
White line you see running through your LCD monitor is a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
Jun 12, 2010 | Televison & Video
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
EMachine tower doesn't boot up. Only the fan is running
try replacing your ram.if your ram is bad you wont get no picture on your monitor but your puter will start.2 if you have a video card turn off you puter for a few minutes and plug your monitor to your original display.
Nov 24, 2008 | E-Machines eMachines Desktop PC
No image but only a bright white horizontal line on the middle
Be it a LCD or CRT monitor, in either case, the screen is gone. Either service or replace.
RDO
Nov 17, 2008 | Compaq FS 7550 17" CRT Monitor
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
Problem with display, need help finding what the problem is
I have the same problem with my monitor and it did not happen until windows update started installing a driver---before that my monitor was working fine. (It was on automatic update) I think it is because the new driver sets the monitor at 100hertz and the syncmaster works best at 60 hertz ( I think).
Since I am unable to see anything on the monitor I do not know how to reset this though. I do think if I could get it working at a lower refresh rate then it would work again---damn automatic updates anyway.
I took my puter back to an earlier date before it had upgraded but my monitor still has the line thing going on. Hope someone has some suggestions for this.
Oct 06, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Computers & Internet Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
