Question about HP Compaq P900 (Pearl, White) 19" CRT Monitor
P900 standby problem
Hello.
When I turn on computer, monitor "wake up" for few seconds, blinking come times and switched to standby mode again. Then I turn monitor off, turn on 2-3 times and it start working.
Can you help me I this trouble?
  • HP Master
  • 2,258 Answers
CRT a relic Cathode RAY TUBE , monitors, why use this?
this monitor is old but has the menu button, see that?
push that, see OSD menu, sure
then turn off all power saver-modes and sleep timers there.
end.
the manual is free to read, RTM? (if googling a week is fun)
circa 2004? HP has no manuals in english. on this mon.
i can only find the manual in Chinese or for hard cash !.
wow, why not upgrade to LCD (LED) displays, 2010 or newer?
be best. for you .!
use that menu button on the front if the monitor
that is the cure !
Posted on Nov 27, 2017
  • 97 Answers
SOURCE: Monitor using 100% cpu and on the blink
Video card is plugged via DVI cable? If the board in the flat panel is going bad ( main signal pcb) video card can be going up and down scale to control its sync with no luck, causing the CPU useage problem.Only ever seen this once. Normally, the monitor will not cause and performance issues other than you cannot see anything.
Posted on Apr 29, 2007
SOURCE: No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Posted on Apr 27, 2009
Bat1956
  • 585 Answers
SOURCE: Dell E152FP monitor goes black at startup, but not permanently
My bet is that your monitor is on it's way out. If this is true, it will get worse until it gets to a point where it no longer works at all. Connecting the monitor to another computer should confirm my suspicion. The monitor has probably developed a problem with some capacitors inside. The parts are not expensive, but finding a shop to do the work at all may be a challenge. If you're handy with a soldering iron you might want to have a try at it.
Posted on Jun 13, 2009
SOURCE: My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? princess242@comcast.net
Posted on Oct 22, 2009
budmrtn
  • 11361 Answers
SOURCE: HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Posted on Apr 04, 2010
I unplugged my computer and turned off the monitor to save power since we were not using. Now with the computer plugged in, when I turn monitor on the green light just blinks.
Make sure the data plug is in correctly. Turn the computer on. No you can try using the power button on the monitor to power it off and on. Or you may need to pull the power for the monitor out of the plug and then put it back in.
The blinking light means the monitor is in sleep mode. They need activity on the data or signal cable before they wake up. Unfortunately sometimes they get stuck and you have to reboot them to wake them up. I have seen a few where they had failed and would not come out of sleep mode but that is pretty rare. Usually you just have to sweet talk it and threaten it a bit and pull it plug a few times and all of a sudden it will start up,
Feb 01, 2011 | Hanns.G Corporation HW173D Monitor
Monitor don't want to turn on. just blinking. what is the problem?
Sound like the video card is at fault on your PC it sends a signal to wake up the monitor if this is not present then PC may appear to start the monitor will be in standby but remains blank.
Replace your video card even if the BIOS chip says that it is present this will solve you problem
Apr 24, 2010 | Acer P191WBD LCD Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
No signal after standby/power interrupt
check in BIOS to see how wake up is set
Also right click desktop go to properties/settings/advanced check setting for wake up
Jul 22, 2008 | Diamond Multimedia Stealth S60 RADEON...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Television
what is wrong? its damaged internally on one of the pcb boards most likely the power board, you will need to take it in to a service center to know what is exactly wrong
May 10, 2008 | Sony 21" Trinitron P202 Flat Screen...
Motherboard doesn't wake up the monitor
Place your finger on the heatsink for the chipset. Feel around for any extremely hot chips. If you find this, your Bios is shot. If you cannot locate the bios chip, just feel all the chips. The Bios chip should be mildly warm but never HOT!
Feb 19, 2008 | ASUS P4SGX-MX Motherboard
Monitor setting
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=223913&lang=en&cc=us&prodTypeId=382087&prodSeriesId=221018&taskId=135 Here is the site to update the monitor drivers for the P900. http://www.nvidia.com/page/pci_express.html not sure what kind of video card you have but you should update the drivers too. I just put the nVidia site incase that was your brand. Good Luck, Tim.
Feb 12, 2007 | HP Compaq P900 (Pearl, White) 19" CRT...
HP Compaq P900 (Pearl, White) 19" CRT Monitor Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
