Question about Toshiba Satellite A10 Notebook
Want To Replacing My Toshiba A10-S330 Hard Disk
I want to replace my hard disk notebook with much bigger capacity, for now, I had a 40GB.
But, I didn't know what is the biggest maximum hard disk capacity of Toshiba A10-S330 bios and motherboard.
Any answer?
Thanks
Irfan
  • irfantea Dec 12, 2007
    Hi Benimur,
    I already check my hard disk, and the consumption rating is same as your image, its DC+5V, 0.7A.
    Thus, I will use this consumption rating as my clue to choose a new hard disk.
    So, my assumption is that I can use any hard disk capacity bigger than 40GB, if the maximum power consumption is DC+5V, 0.7A.
    Is that right?
    Thanks
    Irfan
    PS. My plan is to buy 120GB or 160GB hard disk.
  • machinakias Feb 18, 2008
    hi there! i have the almost the same problem...the thing is how to replace the hard disk....??? which screws are right to uninstall the disk? thanx in advice.!
    Brigadier General:
  • 6,966 Answers
Normally you can upgrade to a new hard disk to the next bigger size, so from 40 Gb, then perhaps a 60 or even an 80 would work. Even if the BIOS/motherboard would not recognized the new size, Windows XP would and be able to access it.
However, I don't think that the size should really be the main concern. I think that your selection should be based primarily on the power consumption. Most laptops have a preset power distributed to its devices. If you are going to use a bigger size HD with a bigger power consumption, Windows (or even your BIOS) might recognize it but the power distribution might be over worked.
My suggestion would then be go to the next size but keep in mind the power rating/consumption of the old when selecting.
I am enclosing an image of my laptop's HD. Pls note the rating DC+5V 0.7A for this 60Gb HD. The 0.7A is its current consumption/rating.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Posted on Dec 12, 2007
  • Louie  Role
    Louie Role Dec 13, 2007
    Hi again,
    As LaptopRepair posted, anything should work.
    Cheers.
Can i put a usb external hard disk drive on to my netbook and would it make the memory bigger how much bigger can i make it .
It really depends on the capacity of your external hard disk. If it has a larger capacity compared to the one on your notebook, then yes it will make the memory bigger.. Take note, we're talking about memory or storage space and not memory as RAM.
if you want to improve the speed of your notebook then we should talk about RAM Memory. If that's the case, you need more RAM and not hard disk.
Please also remember that notebooks can handle only one hard disk. So, if you want to put your external hard disk into your notebook, you will have to remove the other one.
Regards..
Sep 11, 2011 | ASUS Eee 4G Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Toshiba a10 does not give me the option to put lan
          Are you trying to install Windows or reinstall Windows?
          The PXE-E61 POST error means the BIOS cannot detect the hard disk, either a faulty hard disk or a faulty disk controller.
          Check the BIOS and see if it has detected the hard disk, some BIOS also have a hard disk diags, if so run it to test the hard drive.
          My guess is that you have a faulty hard disk.
          Jul 01, 2009 | Toshiba Satelite A10 Notebook
          I'd like to upgrade the HD of my Thinkpad 570 2644-1AG from 4GB to 10MB or even more. IBM system FRU parts list only shows 6,10 and 12 GB as compatible drives. I have found a 40GB Toshiba IDE drive ,...
          It most likely will work, but the BIOS (might be too old) may not allow you to access the full capacity of the hard disk.
          You would normally lose approx. 10% of the capacity when you format the hard disk.
          Apr 15, 2009 | IBM ThinkPad 570 Notebook
          Hp pavillion9000 notebook hard disk broken
          yes, just insure that you have the correct hard drive.... ata or sata.
          Jan 26, 2009 | HP Pavilion dv9000z Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          Hard disk
          not too hard..should be a couple of small cross screws under the bottom, just remove them, and slide out the old drive..
          May 12, 2008 | Toshiba Satellite A10-S100 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Toshiba Satellite A10 Notebook Logo
          374 people viewed this question
          Top Toshiba Computers & Internet Experts
          pankaj rautela
          pankaj rautela
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
