Question about Sony Ericsson K610i Cellular Phone
Dead phone red light apears as you charge but if u push the power nothing happens
  • ngo2 Dec 12, 2007
    just want to know if the problem of my phone lies on the software or hardware
  • 3 Answers
Try to take the memory card out it worked on my w200i when finding network put back in try that
Posted on Apr 03, 2009
    President:
  • 1,944 Answers
Hi, Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson Update Service) which is free and if that doesn't work then you will need to use wotanserver(requires credits=money) or send it to a service center. Good luck!
Posted on Dec 12, 2007
  • Damen Wong
    Damen Wong Dec 12, 2007
    If the solution I provided helped, then it's a software problem. If none of the above helped then it's a hardware problem (ie. battery died or malfuntioned) but chances are it's a software problem.
Playstation lights turn on, But nothing apears on screen?..........
Did your previously had it hooked up through hdmi????? Are you getting sound????? Try with the standby light on pushing in the power button and holding it until you hear a beep or two then let go....wait a few 10-15 seconds and see what happens....
Mar 28, 2012 | Video Game Consoles & Games
I swithced my fone off and im trying to swith it on and it just doesnt swith on wah am i meant to doo!
when you turn your phone on only the keypad lights up right? or nothing happens?
if nothing happens charge your phone til red led on side turns off
after that please continue to read
its a w980 software problem, very common
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
please note this will restore phone to factory state
Nov 16, 2009 | Sony Ericsson Walkman W980i Cellular Phone
My phone is not starting
hmmm well idk there should be a red sticker that should be white with red pluses on it but if its red then it probably got wet somehow the sticker should be on the battery and in the battery slot but if thats not what happened then might wanna plan a funeral O.o
Sep 01, 2009 | ASUS P527 Smartphone
Unable to turn on and showing red light
the same happened to me the battery has had it get a new battery and it should work
Mar 15, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
I have a Sony Ericsson k810i phone since April 2008.Today I connected my cell phone with my pc via usb connection.My phone was turn on and I had choose the "operate as a cell phone" application on the...
First thing is never remove the cable without stopping the USB connection from system tray. Now, as your phone has gone kaput, you will have to re flash the firmware. Checkout some SE forums like esato.com,se-nse. Use a memory card reader to copy the contents of your m2 and don't keep it inserted in the phone while flashing.
If your phone is still under warranty, i suggest you take it to the service center.
Jan 10, 2009 | Sony Ericsson K810i Blue Smartphone
Power on Problems
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Sep 18, 2008 | Motorola Mobility RAZR V3
Phone completely dead
This is a very odd problem with an even "odder" solution. When this happened to mine, I found a website that told me the following. I swear it works... eventually... probably.
Take the back off and just set it aside for a few minutes.
Now, remove the battery, and then put it back in, and then press the power button. If that does not do it, repeat the process...
... like 20 or 30 or 40 times. Eventually, the unit will make a (scary sounding) "pop" noise, and should turn on as normal.
I have had 3 Tilts. (I tend to be hard on phones.) Of those, two have had the "death" issue. Both were resuccitated this way, and worked just fine afterward.
Best of luck! Hope that helped. :-D
Jun 21, 2008 | AT&T 8925 Tilt Smartphone
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
Sony Ericsson K610i Cellular Phone Logo
142 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
