2000 Cadillac DeVille Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stalls when going up hills. - 2000 Cadillac DeVille
Anonymous
Level 3:
  • Master 305 Answers
  • Posted on Sep 15, 2009
Anonymous
Master
Level 3:
Answers
305
Questions
0
Helped
136320
Points
1001
Sounds like a weak fuel pump, not enough power to draw fuel under high pressure
My car stalls after going up a hill
Start with the fuel filter. Could be the fuel pump also. Pressure would have to be checked.
Car lunges and stalls especially on hills but restarts
change your fuel pump filter and put some injector cleaner through a half tank of gas and drive
1998 Cabrio stalls on a hill. Will not
check the bellow on the throttlebody it is probibly cracked they dryrot
1997 Ford escort manual trans stalls when driving up steep hill.
sounds like a fuel issue how are the rmp's when going up is the vehicle starving for fuel may be a restriction in fuel system
How do i adjust low rpms
IF it is stalling going up hill then just put it into a lower gear.... or if that is not an option then you can turn the idle screw clockwise to increase the idle but it is not recommended. The car has a set idle for a reason and the systems within it are designed for that specific idle.
WONT GO UP HILLS AND STALLS
Do you have any check engine lights etc on dash?
Have you checked for stored codes?
1-Bad --Ignition Coil
2-Bad--Egr Valve.
3-Bad--TPS Sensor
3--Fuel Filter Clogged
4--Worn out and Clogged Converter
Check out those possibilities,one at a time.
Why does my 98 honda crv stall when coming down a hill?
when I make a sharp right turn with my 98 honda crv, I get a "squel' from the back right tire. I also sometimes get a squel that something is slipping when I accelerate from a stop light
My 2001 GMC sonoma stalls out going up hill?
how much fuel in tank and how long driving uphill???Pump may be running dry
2answers
Car stalls unexpectedly.
get a new timing chain then tune it up
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
