I've been using the P200 Subwoofer for over a year with no issue until one day I notice no sound coming from it. I took a look and can still see the powered light is on, shutting off and on (power cycle) didn't help. Checked the fuse, still good. I've let it sit with no power for a few days and revisit to see if I've missed anything. Still no luck. What could be the problem?
Try taking tha cable out of the amplifier and touching it, this should create a low hum, as your body is sending throug a small current. if this works then you may have accidently switched the sub woffer on in the amplefier. if however you get nothing through the sub then you may have a dry joint in the solder, or the board may be dead. Other option, try an other cable. they also use lead based solder so they do get old.
Was this solution helpful? Show your Appreciation by rating it:
