Question about Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
Whirlpool freezer and the refrigerator.
The fridge i have have started accumulating ice in the freezer behind the freezer box and the the cool air does not pass to the beolw chamber and the whole fridge stops working. if i deforst it for 24 hours. it starts working again and the problem re starts after 4 - 5 days the freezer is not able to get rid of ice accumulation on the pipes that create the chilling temp.
  • 1 more comment
  • Anonymous Dec 30, 2007
    Water is accumulating on items in refrigerator. What is the problem?
  • flem03 Mar 24, 2008
    I have a whirlpool gold fridge model number GR2SHTXKQ01 the freezer seams ok but fridge is not cooling. I have notice in the past that somtimes water drips from somewhere inside the fridge at the back. Also notice ice build up in two holes at the top inside fridge not sure if this is where the cool air should be passing through. I unpluged the frige and plugged back in to see if it would restart.
  • WVater9419 Feb 22, 2009
    ice accumulating in the bottom of the top mounted freezer section & water in the refrigerator shelves & bins
    Problem Solver:
  • 12 Answers
Chances are your defrosting clock is stuck or quit working.
The clock works as timer to set time for defrost, at which time it stops the compressor, and turns a heater tube next the cooling coils to melt ice. It depends on your expertise if you want to try replacement,as most replacement are universal, and some rewiring is sometime involved. The clock is usually in front at the bottom behind the removable grill, or in the back. It looks like a square box with a dial that has a one way turn knob. To check use flat screwdriver to slowly turn dial (you can only turn one way) until the compressor stops, then wait to see if compressor starts back on it's own (it might take as long as 30 min.).
If it does not start it's bad and need replacement. Of course you can turn dial again until it starts again so you can use fridge. If it does start it could still have been the problem where the clock got stuck, and you got it going again by turning the knob, but let it run. If it works for a while and then have the same problem again the replace clock.
Hope this helps you
Posted on Dec 15, 2007
Whilpool uses a fan at the back of the freezer to circulate air. If it burns out, the fridge will still cool, but not as well.
However, these don't usually burn out. What usually happens is that ice builds up and prevents air from circulating. If that is the case then you probably need a new bimetal temperature sensor on your cooling coils. This sensor sits at the back of the freezer (behind the wall) and tells the fridge when to defrost. If it doesn't then the ice will plug up the vents and may even stop the fan from working. Hope this helps.
Apr 15, 2014 | Whirlpool Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Whirlpool refrigerator type 21TFA refrigerator won't cool - air vent in freezer keeps icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Feb 25, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
There is no cooling in my fridge but fridge is on,fan is working but no cooling
it can be any of 3 issues,either the damper vent door between the freezer and refrig is iced up and cant open and close,or the motor that operates this door is bad or without power,then the evaporator coil in the rear area behind a panel inside the freezer is iced over and you can't blow cold air over a solid wall of ice,if this is the case the rear wall inside the freezer will have ice buildup on it,then it can be a bad ptc contactor overload relay on the compressor keeping it from starting and cooling the unit
Nov 16, 2010 | Whirlpool Refrigerators
Refrigerator side not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
208 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
