Question about JVC AV-32260 32" TV
Won't powwer up
Pwr/timer lamp lights for about 5 secnds, then flashes. Never comes on with picture or sound.
  • 934 Answers
Hank,
From what you're describing it could be one of several things so this thread may take a bit as you check some things and report back... In doing so, don't rate this till we've had a chance to look at a few things then you can call me a idiot with a poor rating...
First off lets change a couple of simple caps. C931 is 100uf/160v and is a common failure in these units. Also C933 which is a 1000uf/16v in fairly close proximity to each other. This cap also, by itself, can cause this symptom.
Try these and let me know what the result is.. I am assuming of course that you know what a cap is, how to solder and some of the basics to do this repair for yourself, correct?
Bill
Posted on Dec 12, 2007
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Hitachi 50v500 turns off, then back on.
shanerickp, how many flashes before the picture comes back? that could be your code for a lamp replacement. check your owners manual for that.
Jul 30, 2009 | Hitachi Televison & Video
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Symptom: LAMP Led Blinking Cause: Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss.
May 13, 2007 | Hitachi 60V500 60" Rear Projection...
JVC AV-32260 32" TV Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
