Canon MIXPA MP530 Memory is full
MP530 will not accept fax phone number as screen shows "Memory is Full"
  • Jolly Jerry Dec 12, 2007
    Please help this senior citizen
    Jolly Jerry
  • texastaxman Mar 26, 2009
    Cannon Fax-Phone L120 will not receive/nor send faxes, due to memory being full - turning it off and letting it sit did nothing - ideas anyone? Can not find the manuel or instruction booklet that came with it. John. Thanks.
I found this in a forum and I suspect it will work, remember that you'll need to clear the internal memory chip by unplugging the printer:
I got the dreaded "memory full" problem with my mp530 this morning. Couldn't FAX because the mp530 thought its memory was full even though it showed no documents in memory. The Canon site lists this symptom with a solution of 'turn off the unit, wait 10 seconds, then turn it back on'. Well that didn't work, so after multiple tries I noticed a post on this board (not really related) that suggested turning off the unit, unplugging it and waiting 10 minutes -- and that did the trick.
Posted on Jul 30, 2008
  • 1,113 Answers
Jerry, It probally wants ink to print the stuff in memory, if this has been corrected you can make it print from its memory or you can delete each file, it takes a little doing but this is what you need I think to do so you can free up the memory, to delete a item from memory, press menu, then scroll to a memory item, ok , scroll to delete, ok to delete, ok to delete, menu to get out quickly, standing on one leg :-)
You should be aware that this printer has a serious "ink low" behavior. When any ink cartridge is getting low (which still means a lot of ink left by the way), it changes the Fax reception model. Instead of printing your faxes as they arrive, it dumps them into memory. So, even though yellow (say) is low, it will not print your B&W fax!
It takes more than 5 steps to print the fax and delete it (menu, scroll to memory item, ok, scroll to print, OK document, scroll to print all pages, ok, menu to go up, scroll to delete, ok to delete, ok to delete, menu to get out).
Worse, after a couple of these, the memory is mixed up. So, when you want to send a Fax, it will say "memory full" even though the memory is empty. You then have to power cycle the printer (hold down on/off for 1 second, wait 10 seconds, power on, wait for it to get ready (another 10-20 seconds).
This means you either have to waste ink by throwing out cartridges before they are empty, or you have to deal with this mess.
Posted on Dec 12, 2007
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Can not clear memory in my canon MX850
First thing I would try is to reset the device by turning the device off, and waiting a full 20 seconds, then attempting to restart the printer, wait for it to do its full boot up cycle and then try again, if that doesn't work I might e-mail, or call Canon.
Hope this helps,
Ryan Frame
Creative Energy Associates Technical Center
Jul 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannot fax memory is full
Turn off the unit, unplug the power from the wall outlet for 10 minutes, turn it back on.
Hope this helps and have a great day!
Jul 07, 2009 | Canon PIXMA® MP530 All-In-One Printer
Cannot fax ... Memory in use 0%
hii..
how long you have been using this fax.
Nov 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Sep 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  2. Use leftright.gifto select [MEMORY REFERENCE].
  3. Press <OK>.
  4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
    If you select [PRINT DOCUMENT]:
    1. Press <OK>.
    2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    5. To print another document, return to step 4b, or to finish printing, go to step 5.
      If you select [DELETE DOCUMENT]:
    6. Press <OK>.
    7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Memory full display when trying ty fax
Thks for the above info. Went to my 530 to fix same problem and didn"t work. Mem in use light kept flashing. Re-traced phone line and outside line and found they were plugged into wrong jack. Moved the phone to the phone plug and outside line to outside line, and problem gone. This worked for me but there may be other causes that will make this happen
regards
oldcoot
Oct 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
1,836 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
