WD 400gb mybook internal connectors?
Hi, I recently purchased a wd 400gb mybook from eBay, with the external casing removed. The person claimed he cracked the case, and took it off and was going to put another on but didnt have time so he sold it off cheap. I figured it was a steal at $50, and got it. It works and all, but I am trying to figure out what the connectors on the board are so I can make my own enclosure for it. One is a two pin connector that looks like either a jumper cap goes on it, a push button switch, or led light connects to it, and is labeled 'J10'. The other is longways down against the board on the edge, looks like the female end that pins stick into, 5 holes across and 2 high, and is labeled 'J2'.
If anyone has ripped apart a mybook and has an idea, I'd like to know before I stick a power switch on a led connector and blow something up! :)
ps - I think its the essential edition one, as it only has usb and no firewire.
Thanks,
- Dave
  • Superdude688 Mar 08, 2008
    Oh sorry, of course! HDD is WD4000KS (sata), and on the board it says
    WESTERN DIGITAL
    BRIDGE CONTROLLER 1U
    SINGLE SATA-USB 2.0
    and towards the bottom:
    2061-701411-000
    REV A
    COPYRIGHT 2005
    I don't care as much tho now, because i had just throw it into a small cardboard box i had leftover from shipping and recieving things on ebay, and of course that was a bad idea, i knew it would get hot but not THAT hot! (enough to kill it). A few months ago it started clicking and was dead. It was either the heat, pre-faulty anyways, or who knows. most likely the heat tho. I could get it to work about 5 min after cooling down but thats about it. After letting it sit a few more months now it wont even work at all just clicks twice after spinup then dies. Oh well.
    I could still use the info on connectors tho to hook another drive to it and not use a cardboard box this time =]
    - Dave
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    is there any reference on the drive, at all? Board number? anything?
    Guru:
  • 377 Answers
Hi dear
see the picture
1 Western Digital defines a megabyte (MB) as 1,000,000 bytes and a gigabyte (GB) as 1,000,000,000 bytes
WD 400gb mybook internal connectors? - 288b4e7.gifi hope help you
thx
cropp
Posted on Mar 18, 2008
My 320GB WD Hardrive keeps blinking. It is connected via usb 2.0 into my laptop (windows7). Computer Management says it's working properly and it displays all the folders but when I want to open the...
It seems that your Harddrive has problems with internal Micro USB connector. WD, Transcend and Seagate brands are having such kind of problems.
Try to adjust the micro usb cable in such a way that your data transfer or ongoing activity will not hamper. Else to have perfect solution on your problem, backup complete data from the HDD and hand-over the HDD to the nearest WD technical department.
They may diagnose the issue and if not resolvable, will handover new WD Harddrive.
Thanks,
Amar
Oct 07, 2010 | Western Digital 320GB MyBook External USB...
Tip
The computer does not see MyBook anymore
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
on May 04, 2009 | Western Digital 320GB MyBook External USB...
There is an i/o error on some images and music files, on WD passport external hdd
The disk-drive inside the case is "dying".
Try to copy all the files that you can, before it's completely "dead".
Then, if the drive is still under warranty, exercise the warranty to get a free replacement.
If not under warranty, WD has a "customer loyalty" program -- take the serial-number, and buy a new Passport from WD's web-site, citing the serial-number, to get a big discount on the purchase.
Oct 01, 2010 | Western Digital 320GB MyBook External USB...
WD5000MT not recognized
May 21, 2009 | Western Digital My Book Home Edition 500...
Connecting my external 320 to my laptop but its just flashes
May 13, 2009 | Western Digital 320GB MyBook External USB...
External USB Hard Disk is 120GB is not dected in winxp pc.
Jan 14, 2009 | Western Digital 320GB MyBook External USB...
Cannot communicate with my book
Jul 29, 2008 | Western Digital 320GB MyBook External USB...
Ebook 320 external hard drive
May 03, 2008 | Western Digital 320GB MyBook External USB...
I recently purchased a Dell XPS 420 Desktop computer, running Vista, from Dell, including a WD 500GB MyBook external hard drive. The power button did not function from the get-go, but I was able to copy...
Unfortunately if there is no driver for Vista, then your out of luck. Since Vista is a widely used OS and getting bigger, then the MyBook manufactures must create a Vista driver soon or they will be in danger of going out of business. Just wait and periodically check the MyBook website for new drivers.
Feb 11, 2008 | Computers & Internet
How to open the case of a my book wd 320gb
Try this link:
http://www.ransackery.com/western-digital-mybook-open-case-recover-data.htm
Dec 19, 2007 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
498 people viewed this question
David Payne
David Payne
