Question about Amana NAV5800A Top Load Washer
Maytag performa washer
Hi, i have a maytag performa top load washer....it was working the way it should but a few days ago i noticed that it wasnt spinning like it should...it spins real slow...even in wash cycle...i engaged the switch to see how fast the drum spins....it spins but not as fast as it should...sometimes if i give it a helpin turn itll start but again its real slow....when i disengage the switch it comes to a complete halt....doesnt slow down... talked to a friend and said maybe the clutch....can u help me out with a few pointers? thanks
  • 4 more comments
  • Mikeymaytag Dec 30, 2007
    Washer works fine when not under load...then it works fine when a small load is in...I sometimes give it a spin with my hand and that will get it going...I noticed a burning smell when it is spinning slowly and there is a black residue from the belt under the motor...all 3 pulleys spin fine manually with/without the belt. I suspect the belt maybe worn. There are grooves in it and the belt surface facing the pulleys is very smooth. I am going to change the belt and see if this fixes the problem
  • Will Dupont Jul 18, 2008
    My Frigidaire washer is 3 years old and the belt doesn't spin with the spin cycle. The motor kicks in and spins, but the belt just sits and overheats. The tensioner seems to be in place. There is nothing stuck in the agitator. Do you have any idea what it could be. Thanks, three kids and a growing pile of clothes.
  • merv59 Sep 03, 2008
    I have a pav2300 maytag performa top load washer and lately my wife has noticed that the bed sheets do not come out spun enough and has been giving it a second spin. I than noticed or felt the speed was not up there. Have you any hints?
  • Anonymous Mar 25, 2014
    The washer will start the spin cycle but the stop only after several turns. I noticed the belt slipped a couple times also.
    The washer will start the spin cycle but the stop and also noticed the belt slipping a couple times also
  • Anonymous Mar 28, 2014
    washer will spin sometime but not always. If I play with it a little it sometimes will start spinning. how do I get it to spin?
  • 3 Answers
Hi Folks,
I'm guessing both of these problems are related to the belt slipping. There are several points to check.
  1. the belt tension. I'm not familiar with the exact details of your machines, but the usually have a an extra pulley with a spring attached to give the belt tension. Alternatively, the motor is mounted on a movable frame that is held by some springs. These springs give the belt tension. In either case check the freedom of movement of the tensioning arrangement and the springs are providing the necessary tension to the belt.
  2. Glazed belt/pulley - if the belt has been slipping it will polish the pulleys and this will reduce the friction necessary to drive the machine. To fix this the belt should be replaced and the pulley surfaces roughed up with some wet/dry emery paper (not too rough or it will wear your new belt out).
  3. Belt is too old - the rubber becomes hard and brittle and ends up with the same effect as Glazed belt/pulley above. The fix is as per 2 above.
Good luck
Bob Thompson
Posted on Jan 01, 2008
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
I have a maytag performa washer for the pas few months that thing is all over the wash room as it spin. I have cked the belts the springs and any other part I can see or get to but its all over the place...
Have you removed the 4 long anchor screws from the back of the washer? These are used to secure the drum in place for shipping.
I have heard of a few cases that these screws were not taken out and the washer "danced" all over the laundryroom....
Aug 01, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa top loader stopped spinning
GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER AND SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PART NUMBER 1042142 THIS MAY BE THE PROBLEM. IT SAYS A WORN BEARING WILL CAUSE SLOW OR NO SPIN. YOU MAY HAVE NOT NOTICED SLOW SPIN TILL NOW BUT I'D SAY CHANGE THAT AND YOU SHOULD BE GOD AGAIN GOOD LUCK
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa top load will not work
more than likely it is your lid switch asm. I is the switch in the back edge of the lid?
Mar 07, 2009 | Maytag LAT2300 Top Load Washer
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Amana NAV5800A Top Load Washer Logo
853 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
